Which muffs for Xmax 300 (2024 Tech Max)?
Rich_H9
Current Ride: Yamaha Xmax Tech Max
Post by Rich_H9 »
Anyone got any muffs? I've never had them before. I'm leaning towards these:
https://www.tucanourbano.com/en/product ... r369-black
but these:
https://www.tucanourbano.com/en/product ... r363-black
and these:
https://www.tucanourbano.com/en/product ... 4pro-black
also fit.
Why can't they just make one type, so it's easy?
So, any help appreciated.
Re why, it keeps raining and I have heated grips. I like the idea of having just one pair of light leather gloves. And muffs are cheaper than multiple pairs of gloves. Yes, they're fugly, but then my scooters fugly too (compared to say a Ducati 748 or an MV Augusta F4.
Stephen
Re: Which muffs for Xmax 300 (2024 Tech Max)?
Post by Stephen »
I have rhe Barkbuster Blizzards on my Forza 350,they work well for me,keeps gloves dry and easy access to all the controls/ buttons
Steve
Honda Forza 350
Ride Safe Ride Upright
If it helps, I've been using the R363 muffs (or something very similar) on my Tmaxs for the last few years. Very easy to fit, if you ignore the instructions!! The R369 look the same except that there's access to some sort of switch gear. Worth looking into that, as modern scoots with all the electronic gizmos may be difficult to access with conventional muffs.
Muffs are well worth it - keep your hands very warm and dry, though they take a small amount of getting used to. Tucano muffs are without doubt the best and most effective muffs out there - Italians clearly understand the need for warm hands! Infinitely more effective than any sort of hand guards.
Waldorf
Post by Waldorf »
I have Givi Universal muffs for my Forza 350; I had them on my Silverwings, too.
They work for me.
Rich_H9
Post by Rich_H9 »
Thanks guys. I’m going to give the 369’s a go. I’ll let you know how it goes.
Rich_H9
Post by Rich_H9 »
369’s arrived and are being returned. You have to put a spacer on the grip, towards the switch gear. I have Yamaha heated grips. I don’t think I have particularly large hands, but I already wish the grips were longer. With the spacer on there it’s too tight even without gloves, it will irritate me.
Also, you need longer bar end bolts which aren’t supplied. Not a big problem in itself, but something to be aware of.
As I said, I've used the 363s or similar for several years. The instructions were amazingly complex and best ignored! With the 363s you slip the muff over the bar (slot for brake lever), the muffs have a rubber cup that slides over the bar end, which you secure with a cable tie (supplied). Simple. No need to mess with bar end weights or spacers or whatever!
Leadfarmer
Current Ride: ADV350 + R1300GS
Post by Leadfarmer »
Barkbuster Blizzards for me too on my Forza 350 as recommended by Stephen
Very pleased with them, don’t interfere with switches or my Turmoscud
Ministerofsillywalks
My thought about muffs is that on a scooter, if you take your hand, probably your left, out of the muff to scratch your nose or something at the precise moment something happens in front of you which means you have to brake there is a mad scramble to get your hand back into the muff to use your rear brake. Okay it's only seconds but those seconds could mean the difference between crashing and not crashing. Okay on a manual where the rear brake is operated by a pedal and all you lose is your clutch but not on an auto. I would rather have heated grips.
Leadfarmer
Ministerofsillywalks wrote: Thu Jun 05, 2025 9:26 pm My thought about muffs is that on a scooter, if you take your hand, probably your left, out of the muff to scratch your nose or something at the precise moment something happens in front of you which means you have to brake there is a mad scramble to get your hand back into the muff to use your rear brake. Okay it's only seconds but those seconds could mean the difference between crashing and not crashing. Okay on a manual where the rear brake is operated by a pedal and all you lose is your clutch but not on an auto. I would rather have heated grips.
That’s one advantage of the Barkbusters, they’re open rather than being full muffs so they don’t hamper you in any way
Pics…
viewtopic.php?p=313612#p313612
viewtopic.php?p=313470#p313470
