Mk 8 T Max Exhaust water drain hole ?
tmaxrobbo
Post by tmaxrobbo »
I was just looking at the underside of my T Max a 23 plate Mk 8 . There are 2 small holes at the bottom at the lowest point of the silencer underneath . When running exhaust gases come out . I am thinking they are water drain holes but never seen them on previous T Max's I have owned . Anyone able to confirm ? many thanks
tmaxrobbo
Re: Mk 8 T Max Exhaust water drain hole ?
Post by tmaxrobbo »
spoke to yam tech and he thought it would be a water drain hole as exhaust is angled up high . panic defused ;)
Hmmm - the exhaust has been jacked up at silly angles since the mk3, so you'd think they'd have always been a need for such drain holes. I'm not aware of them on any of my Tmaxs, but it has to be said that I'm not one to closely examine the underside of exhaust pipes!
There isn't one on a MK3
tmaxrobbo
Post by tmaxrobbo »
Seems just on the 560 Tech Max
