Forza 750
Ledgy
Current Ride: X max 300
Forza 750
Post by Ledgy »
Hi all, is there any vibration on the handle bars (forza 750)? , I have a adv 350 and while a great scoot the vibration is not very comfortable . Might be looking to change
StephenC
Current Ride: Kymco DT X360
Re: Forza 750
Post by StephenC »
That doesn't sound right. Have you checked to see if a tyre balance weight is missing?
Can is not the same as Should
Ledgy
Re: Forza 750
Post by Ledgy »
It's not been out much, I just took out it of the garage to give the engine a run on It's main stand and it was bouncing all over the place
Re: Forza 750
Ledgy wrote: Thu Feb 16, 2023 11:12 pm It's not been out much, I just took out it of the garage to give the engine a run on It's main stand and it was bouncing all over the place
That does NOT sound right! You occasaionlly get a little bit of shimmer if you rev it on the stand, but not much.
Re: Forza 750
some scoots vibrate on centre stand especially if they have a top box fitted. look up 'grip puppies' on ebay, I wouldn't be without them.
Re: Forza 750
Vibrate, yes...'bounce all over the place' , No!
Maxi Burger
Current Ride: Suzuki Burgman 400 2022
Re: Forza 750
Post by Maxi Burger »
horobags wrote: Fri Feb 17, 2023 10:37 am look up 'grip puppies' on ebay, I wouldn't be without them.
I second that. I found my grips to be a bit thin in my hands so grip puppies serve a dual purpose for me, making them fatter and more comfortable.
steeve139
Current Ride: Honda Forza 750
Re: Forza 750
Post by steeve139 »
Hi, I have a Forza 750 and there are little or no vibrations in the hand grips. Probably Honda could have made it smoother if they hadn't chosen a 270 degree crankshaft - but 270 degree crankshafts are very much in fashoin with japanese parallel twin bikes these days.
