+ marks the pot
knight2
- Current Ride: Burgman 650
+ marks the pot
I may be missing the obvious, again
but what is the purpose of the brake pistons with the + on the end. Le dude says they must be lined up square with the caliper, but why. The one on the back caliper of the Burgman I think is the piston the operates the parking brake. But if I remember right there's one on the front as well, maybe something to do with linked brakes, I think, maybe I should give up thinking it dosen't always end well
- 2wheelover51
Re: + marks the pot
I know some rear brake cylinders with parking brakes have screwdriver slots on the pistons to screw them into position before the brake can be operated
- StephenC
- Current Ride: Kymco DT X360
Re: + marks the pot
This is something which I've learnt over the years - if I don't understand why someone who is more expert than me says to do "X", then do "X". If one day I can work out why X is the right thing to do, then great. The wrong approach is to not do whatever it was and then find out the hard way why it mattered
Not sure I've explained myself clearly but hopefully it made sense.
And yes, I did learn some things the hard way
Can is not the same as Should
knight2
Re: + marks the pot
I think your right though they are a bit big for a screwdriver, I used the pointy bits of an open ended spanner which seemed to fit quite neatly. I would like to know how to set it up properly, will have to have a look on you tube.2wheelover51 wrote: Thu Jan 12, 2023 12:00 pm I know some rear brake cylinders with parking brakes have screwdriver slots on the pistons to screw them into position before the brake can be operated
Yeah I do like to know the why's and the where for's and yes I have found out the hard way more than onceStephenC wrote: Thu Jan 12, 2023 1:08 pm This is something which I've learnt over the years - if I don't understand why someone who is more expert than me says to do "X", then do "X". If one day I can work out why X is the right thing to do, then great. The wrong approach is to not do whatever it was and then find out the hard way why it mattered![]()
And yes, I did learn some things the hard way![]()
Thanks for the replies always appreciated.
