Hi All
Happy New Year!
Fitted my Tucano Urbano Thermoscud R190 to my Yamaha Xmax 300 this morning.
The fit is ok, but the parts that screw onto the forward footrests that the Thermoscud velcro's to seem too narrow for me to get my foot into the feet forward position.
I have size 8's. I can only ride in the foot 'flat' position.
Anyone familiar with the fit and if this is just the way it is - or whether I can adjust somehow so I can still use the forward foot rests?
Many thanks!
Tucano Thermoscud on Xmax 300 - fitting advice
five50
- Current Ride: xmax300
- StephenC
- Current Ride: Kymco DT X360
Re: Tucano Thermoscud on Xmax 300 - fitting advice
I see you've had plenty of views but no one has come forward with their experience. Sadly, although I had a 300 I never fitted one of these so I am probably just as unhelpful!
I do recall that the foot forward position is a bit tight and so I'm not surprised that the apron is making things worse. I wonder if the only solution is to have an extension of some sort to push it away. So I was reminded that I fitted wind deflectors to my Satelis and wonder if there might be any for your scoot? A quick search throws up a set for the previous gen Xmax so there may be something out there for you? - https://www.ebay.co.uk/itm/174424735967
Can is not the same as Should
five50
Thank you - really appreciate you taking the time to respond. Will take a look.
