Beedspeed
wightegi
Beedspeed
I ordered some rollers from them 1 month ago , and have not received anything and they do not reply to emails . Anyone local who can bomb the place for me or is this normal ?
Liam
Re: Beedspeed
I've never used them but I heard some bad reports about them, months ago.
Liam
Re: Beedspeed
I've just had a look on Trustpilot. It doesn't look good.. A lot of people have not received items.
Re: Beedspeed
No experience of them. Just browsed some Google reviews which seem very mixed, to say the least! I get the impression that if what you want is in stock they send it immediately, if its not, they don't bother communicating with you in anyway. People say that some staff are great, others are total tossers.....
wightegi
Re: Beedspeed
Not a lot of money but it would be nice to get a reply or even the parts ,heavier rollers to play with mixed with standard .
- Taipan
Re: Beedspeed
Looks like they're in liquidation and went under owing £300k!
https://scooterlab.uk/gone-bust-its-bus ... peed-news/
- smeghead
Re: Beedspeed
Beedspeed ltd went into liquidation 15/11/18 Two of the directors, Alan Beeham and Sylvia Beeham have another company called Beed2 ltd, this is still a current live company on companies house. There is also a non limited company called Beedspeed which trades from the same address. Beedspeed ltd was a Creditor Voluntary Liquidation which is instigated by directors when the company is clearly insolvent, this is quite a common occurrence. I'm surmising the directors took the decision to cease trading with Beedspeed ltd due to creditor pressure and place the company in the hands of an insolvency practitioner to seek creditor approval for the company to be liquidated. Beed2 ltd was incorporated 7/4/16 so was already set up prior to the liquidation of Beedspeed. So at the moment they still appear to be trading, on paper at least.
iansoady
- Current Ride: X-Max 250 + Norton ES2
Re: Beedspeed
It's a common trick - go bust owing hundreds of thousands (often to HMRC) then restart the business under a similar name. I think directors of companies that do this sort of thing should be banned.
- smeghead
Re: Beedspeed
Sometime it's not the directors fault, they get stiffed by debtors.iansoady wrote: Thu Aug 26, 2021 12:27 pm It's a common trick - go bust owing hundreds of thousands (often to HMRC) then restart the business under a similar name. I think directors of companies that do this sort of thing should be banned.
iansoady
Re: Beedspeed
Sometimes maybe. However I have direct experience where a company went "bust" owing hundereds of thousands then restarted doing exactly the same things, same directors, same address, (almost) the same name......
