Just back £2.35 says made in Taiwan but look at photo lifetime guarantee not sure if B&Q would honour that but hey ho .Pay your money take your chance .Did click and collect save walking around searching for it .
I'd have preferred a 6 side impact one but its not as you correctly say .Will it remove the nut Ill let you know when time comes .I'm well aware of the difference .I'll go for quick buzz with impact gun rather than standing on end of a breaker bar .Thanks for your concern and input .
Bargain indeed if it does the job but as suggested use with care in case you fu*k the Hex on nut up.Being a tight arse I buy used 6 point sockets at an autojumble for a quid,I’d use a 1 1/4†on a 32 mm wheel nut as it would be a good tight fit
