spotted this while cruising the tube. does this mean the old xmax is on it's way ?
although there are a few conflicting comments saying it could be a fake.. ???? but that's happened before an they happened . just like the forza 300...
Yes/No...don't forget the Tmax is relatively light by Maxi standards - the Xmax 400 weighs the same, as do most 400s, so it may not be THAT bad, but Yes, you'd want more power. I can't imagine that they'd actually do a 250 - they'd be much more likely to use the new Xmax 300 engine (possibly with extra grunt).tmaxrobbo wrote: Thu Aug 16, 2018 2:08 pm saw that it is a mk5 T max . But heh I guess they could bring out a 250 . It would be pretty underpowered if it has the same body / frame but only a 250cc engine . Any news on a 530 update ?
Who said that T stood for Twin? In that case, what does X in Xmax stand for?Clive wrote: Thu Aug 16, 2018 5:19 pm If it's a single cylinder (as it says on the video) can't call it a T (twin)Max......have to be a S Max... surely??
