Sat Nov mounting
Rog
Sat Nov mounting
Post by Rog »
I want to mount a Garmin Zumo onto my Burgman 400 K7, as the handlebars have plastic covers. Where is the best place to mount it? Are there any specific mounts for the scooter?
Ta
Rog
rayb
Current Ride: Honda SH300
Re: Sat Nov mounting
Post by rayb »
Someone was selling a mount for a Silverwing. I don't know if it would fit. I got one of these and a waterproof case. https://www.ebay.co.uk/itm/For-Honda-FE ... 4d3a54bc01
Ralph
Post by Ralph »
On my Burger it was just clamped to the mirror in one of those cases
but later out in the open on a cheepo mount.
Ralph
Nr Fleetwood
Scootypuff snr
Post by Scootypuff snr »
There was a custom made mount for the burgman ( I owned one) it went on the stockhead bolts same as the silverwing.
Paid silly money for it got zilch back when I sold it. I like the brake reservoir mounts but have had issue with the weight causing leaks.
Oxford make a strap- nav case Velcro fastens means you can use car sat navs (which are cheap 2nd hand) so I leave it on & it gets nicked no great loss unlike bike purpose ones.
Luckydave
Post by Luckydave »
I made a mount to bolt on top of the brake fluid reservoir,no problem with any leaks,made one for other side to clamp cheap phone holder bought recently from Aldi.I have a lathe which made it easy to make the spherical/ball
Post by Bluebottle »
Ultimate addons mirror mount attachment V2
£19-99 to £24-99 from amazon /eBay or direct
Fits under the mirror stem on various alignments, toothed adjustment on arm, compatible with RAM
Got one on my burg for the Zumo. Works great.
rayb
Post by rayb »
Ralph wrote:On my Burger it was just clamped to the mirror in one of those cases
I have one of those cases and it's ok but I can't operate the buttons at the bottom and have to take it out. So long as I know the postcode, it's fine.
Ralph
Post by Ralph »
I have 2 sat navs one works fine the other sometimes does not detect button presses.
Ralph
Nr Fleetwood
caecilius
Current Ride: Burgman 400
Post by caecilius »
I have a Burgman 400. I used the Ram bolt that is designed to fit on the brake reservoir - rock solid
https://www.amazon.co.uk/s/ref=nb_sb_no ... RAM-B-346U
Alan
