The screen that is fitted to my 1999 burger 400 would be perfect if it were say 2" higher, as then I would eliminate all wind buffeting. I don't particularly want to change the screen until I have discovered whether anyone is aware of an extension that could be fitted to the top. I'm a reasonable handyman and could try making one myself if there are no off the shelf ones.
Any ideas?
screen "extension"
isbfan
- Current Ride: Yamaha 900 diversion
Richard
- Current Ride: Nss300
stevew
- Current Ride: Maxsym 400i
Re: screen "extension"
Orpington, UK
2014-Honda Wave 110i
2013-Sym Maxsym 400i
- roadster
I have just made one for my Triumph using a Chinese ebay screen supposedly for a Harley. Cheap enough for some trial and error. I have mounted it with the rubber type expanding nuts along with extra grommets. Carefully drilling holes with new HSS bits went OK using plenty of masking tape over the Perspex to protect it and to mark out. The material can be trimmed to size using a jigsaw with a fine toothed blade. The rubber nuts are sometimes described as 'wellnuts' which I suspect is a corruption of Weldnuts unless anyone knows better.
Scootypuff snr
Stevestevew wrote:I have one of these........works well.
How long have you had the wave??? Looking at your list is the RE now gone
stevew
Had the Wave for a couple of months. Lots about it on the C90 forum.
Enfield is "resting" with the head off ATM and is going to be sold in the spring..
I'll pop a review of the Wave in the mini Muppets section.
http://www.maxi-muppets.co.uk/forum/vie ... 52&t=20339
Orpington, UK
- Stephen
Yep i can recommend the laminarlip as well,just the ticket for me,noise and buffeting significantly reduced.
Steve
Honda Forza 350
Ride Safe Ride Upright
- roadster
Here is my cheaper solution as described above
Not actually fitted to the Kymco ( which has a decent screen to start with) but tested at 90mph and exactly correct height for me. Total cost using Chinese stuff from Ebay about £20.
isbfan
Nice one roadster, food for thought
Richard
Fitted a Laminar lip on mine today....road test tomorrow.
Tried to add a picture....for some reason beyond my knowledge it will not attach.
