suzuki burgman 400 1999
Hi went for a ride came back changed the engine oil filter and final drive oil went to start bike just got a clicking noise all the lights work relays work kill switch works has new battery power going to starter motor if I take starter motor out connect live and earth the starter works all switches work but engine won't turn over any information would be a great help thanks dale
- kishan
Re: suzuki burgman 400 1999
check the spark plug.
- Current Ride: Forza 125
Seems something may have been disturbed during maintenance. Need to go through all the connections. I presume the side stand and the brake switches are OK?
I don't think it's the plug.
i bought a new battery for the nexus a few years back, rode it for two weeks then went to start it,all lights came on etc etc etc no joy just the click..... you start to look everywhere, a couple of weeks passed, as i was going on holiday, came back and phoned the breakdown people, the guy jump started (piggy backed my battery) and it started straight away... so it was the new battery that was knackered..... lesson here is the battery might show to have volts but no cranking amps, so before you start to dismantle any more, get some jump leads from a mates car (engine not running on car) to your scoot then try again to start the scoot. if the scoot starts, you either have a knackered battery..... OR as you may find that the reason IS
the battery might not be knackered ( just run down) but the generator or regulator is at fault for not charging the battery when riding, so if you get it started then you need a multimeter on your battery, needs to show above/at least 12.6 volts dc at tick over and 14.5 volts at steady 3/4000 rpm
by the way welcome lad
- Current Ride: 2009 Burgman 400
As Michael says it really does sound like a faulty/flat battery. Or, and I'm not even sure if there is one, it could be the starter relay either playing up, knackered or just loosely connected. Again or, check the main earth to make sure that's not loose or corroded.
2009 Burgman 400 in sunny Perranporth
Always seek the happy medium - she's out there, riding her scooter.
DITTO AS ABOVE, (ooops cap lock on) if the scoot was turning over and not starting that is another issue entirely , but not turning over needs to start with basics first
For a numpty, why not have the car motor running when jump starting a scoot?
- johnp
- Current Ride: The Wife
just for safety really, as someone may have it running before applying the jump leads and the scoot switched on, its suprising what some folk do, save you blowing fuses on the scoot, the cranking amps of a car battery is way over the cranking amps needed for a scooter so dont need to be boosted like you do car to car..Gerard C wrote:For a numpty, why not have the car motor running when jump starting a scoot?
and the jumping leads put Positive on first good battery then flat battery car +.... then negative on good battery then fit the negative to the flat battery car on the engine metal, eg engine block etc (everyone sticks it on the negative battery terminal) dont know whats the difference
