Sym gts 300i evo brisk plug
marval
Current Ride: Aprilia sr gt
Post by marval »
Sorry if this question has been done to death, but I am far too old to understand the mechanics of forums! Anyway I due to all the positivity regarding Brisk plugs, I would like to put on in my ,2011 Sym 300 gts evo. There does seem that I can find some suggesting the AO12 and others the AOR14. Any advice appreciated.
Re: Sym gts 300i evo brisk plug
marval wrote:Sorry if this question has been done to death, but I am far too old to understand the mechanics of forums! Anyway I due to all the positivity regarding Brisk plugs, I would like to put on in my ,2011 Sym 300 gts evo. There does seem that I can find some suggesting the AO12 and others the AOR14. Any advice appreciated.
if you know and post here, the NGK plug you are using now, then i will be easy to advise which you require cheers :D
Globs
Current Ride: Piaggio X10 350
Post by Globs »
If it's the 263cc efi engine (great engine BTW) then it's a CR8E with a gap of 0.6-0.7mm.
picture hosting
marval
Post by marval »
Hi, yes its definately the 263cc, and also your righ about the current plug, iy is a CR8E.
check thread http://www.maxi-muppets.co.uk/forum/vie ... 49&t=16181" onclick="window.open(this.href);return false; as same as the burg 650.. so same buying places :D
or this supplier if your plug nipple is on the end of your ngk plug http://www.ebay.co.uk/itm/AOR12LGS-Bris ... 53e929ad45" onclick="window.open(this.href);return false;
marval
Post by marval »
Thanks Michael, Viewed the link and supplier was on my radar.Solves my problem thanks again
