X Max 400 seat
2215WU
Current Ride: X Max 400 Lambretta Ser 2
X Max 400 seat
Post by 2215WU »
Has anyone else got this on there seat on an X Max 400 seat stapling underneath looks original can anyone confirm
Thanks in advance for any help
Globs
Current Ride: Piaggio X10 350
Re: X Max 400 seat
Post by Globs »
I'm a bit confused - what are you showing on photo 1?
2215WU
Re: X Max 400 seat
Post by 2215WU »
The raised bit at the rear of the riders seat looks like extra padding has been fitted but the under seat staples look unmolested just wondering if this is standard
maxiscoot nz
Current Ride: maxi
Re: X Max 400 seat
Post by maxiscoot nz »
your correct someone has done a bad job of putting in extra padding and not streched the cover back on correctly and split the main cover away
maxiscoot nz
Current Ride: maxi
Re: X Max 400 seat
maxiscoot nz wrote:your correct someone has done a bad job of putting in extra padding and not streched the cover back on correctly and split the main cover away
In photo 2 to the right of the stapples you can see little holes where the original stapples were. Thats what it looks like to me .
My freinds call me eagle eyes
2215WU
Re: X Max 400 seat
Post by 2215WU »
Thanks for the replys I will now look at removing it as it looks poor didn't want to start if it was standard
Re: X Max 400 seat
possible gel type insert?
2215WU
Re: X Max 400 seat
Post by 2215WU »
Found the problem the previous owner for what ever reason had stuffed it with sponge gone in from the top of the seatImageImage
