Hey,
I've picked up a Peugeot BB frame and tank (I think late 50's early 60's) on ebay with the plan of rebuilding and was hoping that I would be able to get advice and guidance from some of you seasoned professionals.
I'm not looking to restore but rebuild with whatever parts are readily available and look good.
So here is my first question:
Engines - I want to put a 50cc 2 stroke on it. Can anyone suggest an engine that is reliable and parts easy to replace. Knowing that it's going to be near impossible to find one that fits I have no doubt I'll be fabricating mounts.
Also any suggestions on reading material about engines, as the gaping void in my brain about them needs to be filled.
Cheers
Wes
Rebuild Help
- JohnR93
Re: Rebuild Help
- Current Ride: Forza 125
Re: Rebuild Help
If I was doing such a project my first stop would be a bike breaker in your area. There shuold be plenty of scooters there dumped by 16 to 17 yr olds for useful bits that you will require. Good luck and let us know how you get on, you may start a new trend.
- ridinhigh
- Current Ride: GTS 300
Re: Rebuild Help
Hi wes,
you would be better off to sign up on scooternations site ,they have loads lads doing all sorts of tuning
and engine swaps on small two strokes,its also a very friendly site,
Wes
Re: Rebuild Help
Thanks 'ridinhigh', will take a look.
- BenR
Re: Rebuild Help
If you are fabricating new mounts to put a different engine in (does it have to be 50cc?) I would suggest using the Minarelli AM6 engine as they're still in use today, parts are cheap & plentiful plus it's probably the most reliable & well proven 50cc 2 stroke ever.
