Screen scratch removers
- smeghead
Hi good people of Maxi-muppets. I wondered if anyone has any practical experience of a suitable scratch remover for plastics screens? It's for the caravan windows, both myself and a work colleague have 'vans and both have fine scratches on the windows, nothing deep you understand but fine and irritating when the sun shines on them.
- JohnR93
Re: Screen scratch removers
I have used Xerapol. It does work but it's hard work...
[BBvideo 560,340]http://tinyurl.com/n6o8e7x[/BBvideo]
- bornagainbiker
Yes and It can be got on eBay here http://www.ebay.co.uk/itm/111227110422? ... 1423.l2649" onclick="window.open(this.href);return false;
- JohnR93
Thanks BaB, I'd completely forgotten about a link to purchase it... Doh!
has anyone used this on a car headlight
not sure if this would do the job but one of my headlight clusters is looking misty and slight green tinge to the outside, thanks in advance, not sure if there is owt else i could use
- mottza
+1JohnR93 wrote:I have used Xerapol. It does work but it's hard work...
- irev
- Current Ride: AN400
Toothpaste can also work. Try small area first.
And leaves a minty fresh window...
It depends on the material
Xerapol is for cleaning acrylic/Perspex. It has a small amount of solvent as well as abrasives so it can redistribute some of the material and fill the valleys as well as smooth the high points.
It is going to work better than toothpaste.
Xerapol isn't recomended for Polycorbanate which is much tougher but doesn't play nicely with some solvents (alcohol is OK, ammonia isn't )
Novus #1 or Novus No.1 is used on Polycorbonate
Polycarbonate is going to take more elbow grease to polish.
Most toothpastes contain abrasives, some contain mica crystals which will make a reasonable cutting paste for Polycarbonate. So it depends which toothpaste you choose.
The best source I've found for plastic care/polishing is boat chandlers. Boats have more care lavished on them so the staff tend to know more about the products they stock and have more materials technology knowledge. Sadly most of the motor trade know sod all about plastics and think they are all the same. Boat chandlers are your kiddy for plastic.
Brasso can also be used to polish out scratches in plastics:
It is used to polish CDs, DVDs, screens, and pools in order to repair scratches. It is a mild solvent and an extremely fine abrasive, so when applied to the reflective surface of the disc and rubbed radially (in straight lines between the edge and center), it can smooth scratches and reduce their effect.[5][6][7]
you get good results with Brasso
Brasso has also been used by watch enthusiasts to polish scratches out of acrylic crystals on watches.[9]
Brasso can be used to clean Nintendo Entertainment System cartridges to remove dirt buildup that may have accumulated on the metal contacts over the years. This helps to create a better connection between the game cartridge and the 72-Pin connector inside the console, reducing the chances of glitching or freezing caused by a poor connection.
Brasso can be successfully used to take minor (white) heat marks out of French polished wooden surfaces. The fine abrasive cuts through the surface and allows the solvent into the wax and lacquer layer. The surface should be properly cleaned and waxed after this treatment.
Honda Wave 110i
Honda Wave 110i
Go sparingly with polishing polycorbonate
It yellows and gets damaged by UV light so it usually has a silane coating to protect it.
Polishing will remove this layer making the item liable to light damage (yellowing and surface erosion/pitting)
Don't try to flame polish polycarbonate either
