On Friday my bike got knocked over by my work fork lift and severely bent one of my newly acquired bar end weights that I had just paid £50 for (the pair).
Not happy and if I can't repair I'm not spending out more money.
Does anybody know where you could buy a plastic cap that just blanks off the end of the bar?
Handle bar end caps?
- masterchop
Single cylinder rumbler
Re: Handle bar end caps?
just use some gaffa tape, im sure they must do a black versionmasterchop wrote:On Friday my bike got knocked over by my work fork lift and severely bent one of my newly acquired bar end weights that I had just paid £50 for (the pair).
michaelphillips wrote:sorry to hear, its surprising that with all the plastic bottles we generally use there must be one that the top could be cut off, or just use some gaffa tape, im sure they must do a black versionmasterchop wrote:On Friday my bike got knocked over by my work fork lift and severely bent one of my newly acquired bar end weights that I had just paid £50 for (the pair).
- masterchop
I suppose I could do. Annoyingly I'd have to remove the grips. I just want to push something down in to them. I mean they are standard diameter bars. I know you can get them for push bikes.
without the weights on the bar ends the vibes will be worse , was yours 18mm bar end weights or the standard 22mm ends
or could be 11 to 17 mm fitment
Capt. R Swipe
Try googling 'handlebar end plugs'
Cycle bar end plugs might work. try the search first for ideas.
Edit: yep the bar weights do dampen the vibes, plugs won't
- poldark
I used a pair of these on my old Burgman 650, perfectly good quality and excellent value.
You'll just need to check they're right for your bars - EBay
Hexatony 2
- Current Ride: Hexagon 125
- phantom309
- Current Ride: nc750sa
Hexatony 2 wrote:If your scoot was knocked over by a works forklift truck, aren`t they responsible for any damage caused ?
you are having a laugh. most companys have a small sign saying , "parking at owners risk" so they don't have to pay diddly
- poldark
They may all have a sign, but that doesn't mean they're not legally liable.phantom309 wrote:Hexatony 2 wrote:If your scoot was knocked over by a works forklift truck, aren`t they responsible for any damage caused ?
But the issue here is it's where he works so how far do you push it with them (if at all by the sounds of it).
