Yamaha TMAX ABS
DougL
Global Moderator
Current Ride: R1200GS
Yamaha TMAX ABS
Post by DougL »
It would appear that it has finally arrived in the UK. £400 more than the standard version at £9099 :shock:
http://www.yamaha-motor.eu/uk/products/ ... de=pricing" onclick="window.open(this.href);return false;
Re: Yamaha TMAX ABS
Ouch, thats an awful lot of beer tokens.
irev
Current Ride: AN400
Re: Yamaha TMAX ABS
Post by irev »
Not when you consider parts cost for a typical spill... much less broken bones and damaged limbs.
For their part, I guess Yamaha are now worried about product liability issues for not having it available in the UK when they will need it for homologation purposes anyway in a few months, and it's been available in other countries for years.
Re: Yamaha TMAX ABS
There again, wasn't the Non-ABS model priced at £8800 when it was launched? If I'm right then at least the price on the non-abs model has gone down a couple of hundred quid, which makes the extra £400 of the ABS model slightly easier to bear....
DougL
Global Moderator
Re: Yamaha TMAX ABS
Post by DougL »
The problem now is that I want one. :roll:
A white one.
Re: Yamaha TMAX ABS
I didn't mean the £400 for the ABS, it was a comment on the absurdly high price of a Tmax.
DougL
Global Moderator
Re: Yamaha TMAX ABS
Post by DougL »
I'm not really sure if it is absurdly high. It has a die cast aluminium frame, lots of fairings and so on. If you were to compare the components to a similarly built motorcycle, then there isn't really a huge amount of difference. You really need to ride one in anger, to know just how good these are.
Sgt Ernie Bilko
Current Ride: 2010 Tmax mk 3
Re: Yamaha TMAX ABS
Post by Sgt Ernie Bilko »
irev wrote:Not when you consider parts cost for a typical spill... much less broken bones and damaged limbs.
And since so many dealers are sitting on quite a few unsold mark 3 units, let alone mark 4 I can understand their reluctance to stock the new ABS model. Even a price cull of old stock isn't enticing punters :?
Master Sgt E Bilko
RA15042699
Co B 3rd Platoon
DougL
Global Moderator
Re: Yamaha TMAX ABS
Post by DougL »
Didn't realise this. At £6.5k these are quite a bargain...
SkuTorr
Current Ride: Tmax Mk3
Re: Yamaha TMAX ABS
Post by SkuTorr »
And when some go straight for the brute power and go to an SRV 850 from their Tmax MK3, vs. a MK4....
2009 Majesty 400 (sold)
