I bought a H4 and a H7 LED bulb of e-bay - about £8
Plus 2 wedge type LED side lights - about £3
Replaced the original bulbs with the LED bulbs, not hard so far.
Now just take a wire from the L/H light that is permanently on (yellow on my bike) to the unused connector on the H4 bulb in the R/H light.
You can just undo the R/H headlight connector and fit a faston in the spare slot.
Because of the way LED lights work both headlights will be on dipped beam and then when the main beam is switch on the LED's in the R/H light just goes brighter.
Job Done.
I still have the same fuse fitted with as yet no problems.
This may not be the best solution , but for me who does not do a lot of night time riding on country roads and want the main focus of my lights is to be seen by others, also I just liked the idea of having both headlight lit at the same time.
I know I will have to put my original bulbs back in for the MOT (a ten minute job) but until then I like the look!
Cheers
Baz
ps: This is a link to e-bay LED bulbs - http://www.ebay.co.uk/itm/2x-T10-W5W-50 ... 0&_trkparm" onclick="window.open(this.href);return false;
From China I know but cheap and arrived safely.
