Second fill up on the Berg tomorrow so will do a calc to see what she is doing to the tank, hit 170 on the trip tonight and it's only just in the red zone. Does a fuel warning light come on if you run it even lower? My read out says 16.6 miles/litre which works out at 77.5 mpg.
Mileage per tank full?
mjf65
- Current Ride: AN400L0
Week two of Burg ownership and the Triumph hasn't made it out of the garage (might go for a Cheddar Gorge ride Wed night
- NorfolkChris
- Current Ride: Suzuki Burgman 400. 2000
Re: Mileage per tank full?
On my burgman 400 I can probably get to 150 miles per tank but that is mostly A roads
Sent from my HTC One X using Tapatalk 2
- halfabusa
No Light, just red section to keep an eye out of to test your bravery
About 175miles is what i was brave enough for a tank. Central london summer time though. Winter it goes down to 160 max.
- Drago
- Current Ride: SYM Mask 125
MY K3 Burgman does 75mpg and it's fuel guage does what the hell it wants! It's as truthful as a politician!
Everytime I ride it I just reset the tripometer and fill up at 180miles.
Current rides
SYM Joymax Z+ 300 2022+
SYM Mask 125 2019-
SYM Mask 125 2019-
mj, I get about 180 miles before I look for fuel. That's general running about on country roads with some dual carriageways. But on a longer motorway run I can go 200 miles before looking. I reckon she goes about 230-240 miles in most circumstances before she is running on fumes if you are going easy with the throttle, but I'm not brave enought to try that!
Sounds good for a 400...
My new XMax400 is returning 66 mpg, averaged out over 9 fill-ups of around 9 lts...
Not always waiting for the light to come on, and looks like there is a little more room after the pump auto-shut off, Handbook states a tank capacity of 14.8 lts,
with a 2 lt reserve when the fuel light goes on... maybe 1 - 2 more to brim it - after the pumps auto shut off - so theoretical range of 200 miles Looks like it prefers a run, even spirited (68 mpg), than the stop-start commute (63 mpg)
Old 250 Xmax was returning 80mpg...
- anonstarter
- Current Ride: Pending
I've got a dinky one for a maxi - a mere 10 litres - and it's sensitive to the terrain - especially when going down steep hills.
I generally get 120 miles before the fuel gauge flashes. When it's really low there's a yellow warning light too.
To fill it to the brim usually takes 7-8 litres and I feel psychologically 'happier' when it has a full tank.
The MPG is around 80 with the stock windscreen in summer and around 75mpg in the winter with the wind and the rain and the Fabbri screen fitted.
Paul, I still reckon you'll get better mpg's after she has a couple of thousand more miles on her and the engine has done a bit more conforming. It will be interesting to see how much extra mpg though. Have you noticed a little more power at this stage?
- Taipan
Sh300i which has given an average of 77mpg so far. All I need out of the 9.5l tank capacity is 2 days commuting of 120 miles, so its doable as my calculations reckon i only need 7 litres for that.
Using a bit more of the twist grip now i've done the 1000 miles, and changed the oil and filter myself...Data wrote:Paul, I still reckon you'll get better mpg's after she has a couple of thousand more miles on her and the engine has done a bit more conforming. It will be interesting to see how much extra mpg though. Have you noticed a little more power at this stage?
MPG looks fairly consistant, slightly better than the Maj400's listed on Fuelly - any more will be a bonus!
