Burgman question
alp231
- Current Ride: X max 300
Burgman question
I am running a k4 Burgman 650 at the moment with 32000 on it seems to be a little rattly from the primary drive do they all do that nobody I know locally has one to compare with ?
Re: Burgman question
Hi mate, it may just need new new variator rollers as they wear down, you tend to hear them more, if you have not got a workshop manual download from here, it will be same as your model... just put the code in at the bottom middle and it will download a pdf file, i think page 36 is the drive inspection part, easy to do, have a read http://www.pdfmotomanual.com/index.php? ... 61c4222cea" onclick="window.open(this.href);return false;
- anonstarter
- Current Ride: Pending
Could it be the "Dieseling" sound?
[BBvideo 560,340][/BBvideo]
See http://burgmanusa.com/bkb/650+CVT+Info" onclick="window.open(this.href);return false; and
http://burgmanusa.com/forums/15-burgman ... -demo.html" onclick="window.open(this.href);return false;
For more inspiration.
650 doesnt have rollers it moves variator in and out with an electric servo motor controlled by ecumichaelphillips wrote:Hi mate, it may just need new new variator rollers as they wear down, you tend to hear them more, if you have not got a workshop manual download from here, it will be same as your model... just put the code in at the bottom middle and it will download a pdf file, i think page 36 is the drive inspection part, easy to do, have a read http://www.pdfmotomanual.com/index.php? ... 61c4222cea" onclick="window.open(this.href);return false;
I think there was some talk of a Polish replacement part on here to cure it do a search
i stand corrected, sospikey wrote:650 doesnt have rollers it moves variator in and out with an electric servo motor controlled by ecumichaelphillips wrote:Hi mate, it may just need new new variator rollers as they wear down, you tend to hear them more, if you have not got a workshop manual download from here, it will be same as your model... just put the code in at the bottom middle and it will download a pdf file, i think page 36 is the drive inspection part, easy to do, have a read http://www.pdfmotomanual.com/index.php? ... 61c4222cea" onclick="window.open(this.href);return false;
- Steve_D
- Current Ride: Honda SH300i
You might want to think about looking on Burgmanusa.com there's plenty of specific Burgman related advice on there. There is a fix for the noise you have - my friend has a 650 same age and mileage as yours. He carried out the modification and it cured the noise. Only took him about 20 minutes but he is a motor mechanic. I think the parts cost him about £130. Heres a link to the thread on BUSA. http://burgmanusa.com/forums/15-burgman ... 650-a.html" onclick="window.open(this.href);return false;
Honda SH300i
Honda SH300i
