Feeling lazy so thought I'd ask in case anyone knows of the top of their head. M.o.t pass questions:
1) does the brake light need to come on with the squeeze of both brake levers (currently mine only works on the right, same with the starter motor)
2) is a led light over the number plate sufficient if it not controlled directly from the main electric source? (My number plate light doesn't work and I suspect its because my wiring is screwed. One of the rear lights is intermittent also)
									M.o.t questions
- masterchop
M.o.t questions
Single cylinder rumbler
Re: M.o.t questions
yes both to brake light  not sure what you mean for led light if you mean from lights switch no as some scoots on all the time anyway so switched ignition feed would be ok
						- masterchop
Re: M.o.t questions
Basically if it's fitted it must be working.
You only need one brake light switch but if two are fitted they must both work.
- masterchop
Re: M.o.t questions
Think I'm gonna just have to bite the bullet and have an auto technician sort the electrics out.
						- masterchop
Re: M.o.t questions
im pretty sure thats all it is as its also intermittant. strangely couldnt seem to find the part online. didnt try that hard though.pikey wrote:Its usually brake light switch on brake lever or have you tested that
Re: M.o.t questions
Unplug connections clean them touch together see if it works just looked on ebay loads on there seems to be screw in type with plunger if it looks likes yours probably is could be just sticking spray bit of wd on plunger try it again with connectors refitted  while unscrewed .If ok refit or get new
http://www.ebay.co.uk/itm/APRILIA-SPORT ... 1877115%26" onclick="window.open(this.href);return false;
				Earl
- Current Ride: Mana 850
Re: M.o.t questions
Normally if they are sticking the break light stays on permanently, it also does this if the plastic end of the switch mushrooms.
						- masterchop
Re: M.o.t questions
Had enough now! Spent the whole afternoon trying to fix my licence plate light.
The wiring just falls apart.
Does anyone know if a battery operated l.e.d stick on light would pass a m.o.t?
