me rear tyre went pan flat in about .000005 of a second...and the tyre unseated off the bead/edge of rim... causing me to hang the rear end out and fishtail to the gutter..... in the dark and heavy rain.... dont ya just LOVE biking...! luckily nothing behind me and only a half mile downhill push back to home....
what i would like to alert fellow maxi scooterist to..... i fitted they tyre myself... i have done hundreds with no trouble...pump up to 70-80 psi make sure bead seated correctly etc....then deflate to 36 psi
the only thing i can think of i did differently this time....when i fitted this tyre i couldnt get the tyre to just seal so the air could inflate it up...i usually tighten a heavy ratchett strap round the tyre and it seals no prob then high pressure seats it correctly....
this time i struggled(garage airline was hopeless) so used a tin of tyre weld and it started the tyre off and i sealed it in normal way...all i can think of is some of the tyre weld got between rim edge and tyre bead and helped the tyre slip off... the tyre doesnt even look punctured...and i was not accellerating or leaning when it slipped off...
i have been riding with this tyre for a good few months no probs in all weathers... thats why it suprised me how it deflated..... i wont be fitting a tyre with this technique again thats for sure.... (although a tin of tyre weld has gotten me home on a few occasions) i also have tyre/puncture repair strips under my seat, but in the dark with no torch they were never going to help.. hope this is a help to fellow scooterists..
