my 07 piaggio x8 250 battery is showing its had its lot on my optimate charger, looking in the instruction manual it does say which size battery it takes, any member know which one it is,to diconnect it should I remove the negative lead first or
does'nt it matter which lead I remove first.
mitmoor
scooter battery
nexusmaximus
- Current Ride: nexus 500-fuoco-burger 650
Re: scooter battery
I just replaced the battery in my Nexus with one of these... fantastic turnover.
http://www.ebay.co.uk/itm/Honda-CRF-250 ... 4167832b74
- R1K SU
- Current Ride: Burgman 650
Re: scooter battery
Doesnt really matter, which you take off first, but try not to touch a screw driver or spanner against anything else metal whilst your undoing the RED one
Yam RD350 YPVS
Honda VFR750
Yam RD 350 air
Kawa GT550
Kawa ZZR600
Yam FZ1s
Burgman 650
Suzuki GSXS1000
Suzuki GSXR1000 K7
Zero FXS
Honda VFR750
Yam RD 350 air
Kawa GT550
Kawa ZZR600
Yam FZ1s
Burgman 650
Suzuki GSXS1000
Suzuki GSXR1000 K7
Zero FXS
DougL
- Global Moderator
- Current Ride: R1200GS
Re: scooter battery
Which is why you disconnect the negative first, then it doesn't matter if you do touch the screwdriver you're using to undo the positive terminal against the bodywork....R1K SU wrote:Doesnt really matter, which you take off first, but try not to touch a screw driver or spanner against anything else metal whilst your undoing the RED one
- TmaX9
Re: scooter battery
Especially on an X9 as they really do not like short circuits. Odd things can happen to digidashes for example.
Re: scooter battery
On almost all bikes I would take the negative side off first for the same reason DougL gave.
Make sure it doesn't flop back into place and remake the circuit too.
Taking off the pos. side first isn't going to hurt anything in itself but is a worthwhile precaution to always do it neg. first, it isolates the battery.
12v/6v is unlikely to kill you but it might make you jump and do yourself a mischief, the surge can harm components and any size of battery is a fire risk.
It is the other way round for positively earthed vehicles but they are very rare these days
