After having (16g) Dr Pulleys fitted to my Tmax for some time now I decided to go back to OEM weights. Like most Yam scoots the Tmax is a bit sluggish on pull away and it really does benefit from the Dr Pulleys. It makes it a much better town bike. But on the motorway its just too revvy.
My Tmax has always been a bit vibey at certain revs/throttle openings and the Dr Pulleys heightened that too. So I after fitting the OEM weights I have found the Tmax is smoother and better on juice but if I'm honest I do miss the extra pull around town the Dr Ps gave it. Maybe a different variator is the best way.
Ditched the Dr Pulleys.
- Taipan
Re: Ditched the Dr Pulleys.
Surely, it shouldn't make much difference on the M-way? By that time, the variator will be on its highest ratio anyway - changing your weights shouldn't change the overall ratio?Taipan wrote:After having (16g) Dr Pulleys fitted to my Tmax for some time now I decided to go back to OEM weights. Like most Yam scoots the Tmax is a bit sluggish on pull away and it really does benefit from the Dr Pulleys. It makes it a much better town bike. But on the motorway its just too revvy.
I've put the Malossi variator on my mk3 - it makes an entirely different bike round town, but it makes no difference on the open road.
- Taipan
The bike is in a constant state of higher revs compared to the oem ones.I suspect at maximum speed the gearing will come into play but everywhere else it will be revving more to achieve the same speed.
- mottza
Maybe you needed some heavier Dr Pulleys.
But when you reach M-way speeds, the variator shouldn't have any more effect. On a Tmax, you reach its highest ratio at around 60mph (I think), after then you are effectively in 'top gear' all the way.Taipan wrote:The bike is in a constant state of higher revs compared to the oem ones.I suspect at maximum speed the gearing will come into play but everywhere else it will be revving more to achieve the same speed.
- Taipan
Ot a mix yes. When I had teh malossi on my last tmax I mixed weights.mottza wrote:Maybe you needed some heavier Dr Pulleys.
Makes sense. Its just being in that constant state of higher revs that gets you thinking. Maybe you dont hear it over 60 anyway but its feels so much more buzzier and louder? It certainly seems less with the OEMs back in? I do seem to use and roll off less throttle at 70ish with the OEMs?MrGrumpy wrote:But when you reach M-way speeds, the variator shouldn't have any more effect. On a Tmax, you reach its highest ratio at around 60mph (I think), after then you are effectively in 'top gear' all the way.Taipan wrote:The bike is in a constant state of higher revs compared to the oem ones.I suspect at maximum speed the gearing will come into play but everywhere else it will be revving more to achieve the same speed.
- Taipan
I re-balalnced the carbs this morning. I seem to have finally managed to rid the bike of its vibes. I blame the poxy carbtune II. Anyone else got a carbtune II? If you have next time your balancing your carbs tap the thing and watch the readings change. grrrr.
