Do I really need a new oil filter?
Re: Do I really need a new oil filter?
As with the Xmax, you change the Tmax filter every 12,000 miles (or 4th oil change) - it used to be every 6000 miles on earlier models I think, so presumably they decided that they did last longer. Ironically Tmax oil filters can fail prematurely by rusting through!!!. By default I normally stick to 12,000 miles, though I guess its not really that much hassle or expense to change more often. 1500 miles sounds unnecessarily frequent, though the 12000 sounds a bit long, especially if the filter is prone to rot!
- smeghead
Maybe, I suppose the question is does the filter last more than 1500 miles.mottza wrote:Could cost more in the long run
- Current Ride: Forza 125
Some makes of filter cartridge rust very quickly, as someone previously wrote if its tightened up with a metal tool it could develop a pin hole.
Change it for that reason alone.
- smeghead
It has a built in mesh filter too Meldrew, when I changed the oil the mesh was absolutely clean, no sign of any crud at all.Meldrew wrote:Why don't you see if there's a magnetic drain plug you can fit at your next oil change. That would pick up a lot of the metal crud and extend the life of the oil filter.
- Ralph
Best thing since sliced bread you will be surprised how much fine mettle can be pulled out by one of these.Meldrew wrote:Why don't you see if there's a magnetic drain plug you can fit at your next oil change. That would pick up a lot of the metal crud and extend the life of the oil filter.
Honda say to change the oil in the Helix every 1000/1100/1200 miles (depending on which edition of the service manual you have). I have always changed it at 1000 miles because Soichiro says so, and it only has a gauze strainer for filtration duties.
Were they were fitted with a replaceable filter that cost £12 I wouldn't hesitate to replace it every year. There might well be no need, but it'd definitely do no harm and for twelve quid - who cares?
- Steve_D
- Current Ride: Honda SH300i
If that’s your thinking, why not leave the oil in for two years too? If a jobs worth bodging, it’s worth bodging properly.smeghead wrote:I was wondering, I tend to do around 1500 miles a year, I changed the oil a few weeks ago and it had a dose of Halfrauds 5w40 fully synthetic. Next year it will need changing again but is it really worth putting a new filter on too? Filters last way more that 1500 miles. What's the perceived knowledge chaps?
Honda SH300i
Honda SH300i
- The Bern
Steve_D wrote:If that’s your thinking, why not leave the oil in for two years too? If a jobs worth bodging, it’s worth bodging properly.smeghead wrote:I was wondering, I tend to do around 1500 miles a year, I changed the oil a few weeks ago and it had a dose of Halfrauds 5w40 fully synthetic. Next year it will need changing again but is it really worth putting a new filter on too? Filters last way more that 1500 miles. What's the perceived knowledge chaps?
Have wheels, will travel
DTO
- Current Ride: X-max 300
In 17 years of owning piaggio scooters I’ve never had the filter rust through , on my current gts300 I change the filter every 2 years as It tends to do low mileage , Oil gets change yearly .
- mottza
The exhaust rusts on the Piaggios instead!
