650 Rear wheel bearings
stuart brown
Current Ride: Burgman 650 Executive
Post by stuart brown »
Can any one describe the symptoms of worn rear wheel bearing(s) ?
I cannot feel any play in the rear wheel, but I can feel a slight vibration that ‘cycles’ on and off at certain speeds.
The Burger is a 2008 AN650e with 6000+ miles on the clock.
Stuart Brown
Matlock
Derbyshire
Re: 650 Rear wheel bearings
You can get vibes from tyres as they wear.If you take caliper off you may feel play better .Or even take wheel out .Not sure if bearing is in wheel or swing arm on burgman 650.Julian
paula4u
Current Ride: Suzuki Burgman 400AN K8
Post by paula4u »
stuart brown wrote:Can any one describe the symptoms of worn rear wheel bearing(s) ?
Stuart Brown
Matlock
Derbyshire
Surely bearings do not wear that fast???? 6000 miles only? What state are the tyres in? That makes a lot of difference.
ooops another Burgman AN400 K8 again and...
YAMAHA VIRAGO DX535 AND XV250
Suzuki SV650S
Skoda Octavia is for lazy driving
Past Bikes: Honda S-Wing 125, Suzuki Burgman 400AN K3, Yamaha YBR125ED, Burgman AN400 K8
They can do with obsesive cleaning with a jet washer .Julian
mikbak
Current Ride: 2001 Silverwing FJS600
Post by mikbak »
pikey wrote:They can do with obsesive cleaning with a jet washer .Julian
Is that what you did? :twisted: :twisted:
I like to keep a layer of road grime on my scoot to preserve it .Plus on a Travelodge car park which one do you nick the shinny one or the crappy looking one.Julian
mikbak
Post by mikbak »
pikey wrote: which one do you nick the shinny one or the crappy looking one.Julian
When we're parked next to each other , they'd leave both of them.... :mrgreen: :mrgreen:
Alan's Goldwing attracted too much attention wherever you go. Give me mucky marroon any day.Julian
davethexton
Post by davethexton »
Hi, I have just had my (second) new tyre put on my Burgman 650 exec (2010) at 14,000 miles and they replaced, under warranty, the rear wheel bearing, they said there was not much movement, but a little bit of noise, and this was sufficient to warrant replacement.
If you see any trace of brown rust on the seals, water has got in and ruined them. Any noise they should be replaced.
