I am servicing my 2019, Honda 300 Forza, and cannot find any reference in the owner's manual, to the grade of oil for the final drive. It just states the grade for the engine oil ( 10/30 Jaso T 903) but does not specify any particular oil for the final drive, It just says 1.28 Ltr to fill, after draining.
Does anyone know what oil should be used in the final drive?
Thanks.
Final Drive Oil
velocipede6295
- Current Ride: ADV 350 Forza 750
velocipede6295
Re: Final Drive Oil
Thanks, I had seen that video, his is an earlier model and he uses 10/30 engine oil. I wondered if it needed a specific gear oil such as Fuchs Silkolene scooter gear oil 80/90 which seems to be quite a heavier grade oil, or is engine oil OK?
Sylar
Re: Final Drive Oil
I also recently bought a Forza. It appears that you use engine oil in the final drive, as was the case with my Silverwing600. i did over 46000 mls on the silverwing and did my own servicing always used engine oil in the final drive,never had any problems. When the time comes for a final drive oill change on the Forza i will use engine oil.
velocipede6295
Re: Final Drive Oil
That's a great recommendation - I'll use engine oil. Thanks for that Sylar.
Re: Final Drive Oil
Just as an aside matter. The viscocity of a 75/90 gear oil is the same as a 10/40 engine oil. Gear oils are not really about being thicker, just more robust in shear stability and sacraficial minerals to protect the gears under extreme pressure. Whether a particular gearbox or gear hub needs a gear oil or engine oil is dependant on the type of gears used in the gearbox or hub eg: helical or straight cut, and the type of materials used in the construction of the gears or hub and the type of finishing/hardening process used. It's all good fun!
Symcity
- Current Ride: Honda SH300i
Pukmeister
Re: Final Drive Oil
The official Yamaha service CD time/mileage matrix for my Mk3 Tmax says to change my final drivecase chain oil every service, which seems excessive. I know its not super-expensive to do and only 700ml but the stuff I drain out is always pristine. Gear oil lasts for tens of thousands of miles in a gearbox, why should an encased chain need fresh oil so often ?
Any Tmax owners know if this is an error in the service schedule for the Mk 3??
I believe it was every 10k on the Mk1/Mk2 ?
Re: Final Drive Oil
What sort of oil is it in the Yamaha chaincase? Engine or gear oil?
One of the reasons the service interval for the chain oil may have changed, is due to a possible realisation that the chains last a lot longer with more frequent oil changes. Some VW/Audi & Nissans and Honda cars now require a frequent gearbox oil change (every 18 months) due to alterations to the types of gears used in some of there gearboxes. Yet some cars previously of the same type with same engines and gearboxes used to go nearly the the whole life of the car with the same oil in them. In addition, oils themselves are constantly evolving whether engine or gearbox oils and may in some cases need changing more often. It's possible also that cheaper or different chains are being used on the latest Tmaxs and one way of getting them to last longer is to change the oil frequently. This is how manufacturers often economise. Less cost to them, more cost to you.
Re: Final Drive Oil
Yes...the book for my mk3 says change every 6k miles, which is definitely a surprise! I always thought it was a major service thing (every 12k miles), and assumed even that was over cautious. I have a vague recollection that on the mk1/2 the instruction was to check the level every 6k miles and presumably change every 12k. Its not even a gearbox, just a chain after alll!Pukmeister wrote: Wed Aug 02, 2023 10:43 am The official Yamaha service CD time/mileage matrix for my Mk3 Tmax says to change my final drivecase chain oil every service, which seems excessive. I know its not super-expensive to do and only 700ml but the stuff I drain out is always pristine. Gear oil lasts for tens of thousands of miles in a gearbox, why should an encased chain need fresh oil so often ?
Random thought - there is a 'gearbox' (as Yamaha describe it) where the drive comes across the bike from the CVT on the RHS to the chain drive on the LHS, with a couple of gears. I only know this as its where a bearing failed on my mk6! This doesn't seem to require any maintenance, which seems rather odd!
