Messerschmitt copy
Dogsbody
Current Ride: Burgman 400 Honda C125 400-4
Messerschmitt copy
Post by Dogsbody »
What engine is it likely to be, 1998 reg, Honda 250 automatic, Foresight?
https://www.ebay.co.uk/itm/TRI-TECH-AUT ... SwELRgBW2W
wightegi
Re: Messerschmitt copy
Post by wightegi »
An auction with classified price but a closing date of the 25th .Is this just to get around eBay fees ?
StephenC
Current Ride: Kymco DT X360
Post by StephenC »
The website the ad directs you to says the donor machine had a 10" wheel and the engine from with either a Honda CN250 (Fusion) and CH250 (Spacy).
It also says it's met it's reserve with a bid at £1600.
Can is not the same as Should
Ralph
Post by Ralph »
Always liked the Messerschmitt, sounds like they managed to get the steering
a bit to org, if you look at a org one it is likely to have cracks on the steering
yoke, the steering is very heavy and quick.
Ralph
Nr Fleetwood
GrahamH
Current Ride: Honda Helix
Post by GrahamH »
I commissioned the last Tri-Tech Schmitt that was produced by the 'factory', i.e. Rick working by himself. It looked great but was a death trap of bad design and bodging. For example a 'new' car had a bald rear tyre which was marked 'front wheel only'....the rest was just as bad. Eventually after a lot of work the car was brilliant and could be driven at 60 mph with no problem. The biggest problem is the track is too narrow, 8" narrower than a KR200. When this was fixed plus a hydraulic steering damper it was OK if treated with reasonable care. Wish I still had it!
Dogsbody
Post by Dogsbody »
The reason I came across it was this
https://p50cars.com/
watch the Clarkson video, very funny. Not sure I'd feel safe driving one locally.
Normsthename
Post by Normsthename »
I saw a Messerschmitt copy at a car show a few years ago.
That one had a Japanese import Honda 250 4 cylinder engine with a 6 speed gearbox fitted 😳
1975 Honda GL1000 Goldwing
GrahamH
Post by GrahamH »
Andy, Are you sure it was not the Tri-Tech Zetta? That was fitted with the 4 cylinder engine but the Schmitt does not have room to fit such an engine.
Normsthename
You are most probably right, it was a three Wheeler of some sort 😀
