Just come across this story about a Yamaha patent for a 3 wheel Tmax.
https://www.cycleworld.com/story/motorc ... ing-trike/
Looks interesting, but expensive & heavy!!The 4-damper arrangement used on the front of the Niken always looked inelegant to me, so whether this proposed arrangement is better we shall see. Whether it ever progresses from a drawing to metal is of course entirely unknown!
3 Wheel Tilting Tmax?
- Stephen
Re: 3 Wheel Tilting Tmax?
You’re right it will be expensive,only becomes heavy if one has to pick it up off the ground
i guess the trike style should make that difficult to do unless the rider or other road user does something really stupid
Steve
Steve
Honda Forza 350
Ride Safe Ride Upright
- StephenC
- Current Ride: Kymco DT X360
Well "expensive" certainly suits the brand.
Can is not the same as Should
newscooter
How much different from the Tricity 300 ???
Different in almost every way, apart from the Yamaha badge! Obviously the Tricity is basically an Xmax 300 with 2 front wheels, whilst this patent shows a 3 wheeled Tmax, with current Tmax chassis / engine etc. Even the front wheel / tilt mechanism is a completely different design, using some sort of wishbones, which is nothing like Yamaha's current 3 wheelers eg Niken.
newscooter
My bad, I've just seen the article in MCN. Things are looking up for when I become too decrepid to mount/dismount from my current trike as scooters are easier to access .
- capitano
Brudelli have put a lot of work into that leaning front end. Echoing everyone's thoughts on here, it will undoubtedly be both excellent and expensive.newscooter wrote: Tue Jun 09, 2020 8:53 pm My bad, I've just seen the article in MCN. Things are looking up for when I become too decrepid to mount/dismount from my current trike as scooters are easier to access .
https://www.brudelitech.com/#
Just to add further confusion, an entirely different Yamaha leaning 3 wheeler has emerged...
https://www.bennetts.co.uk/bikesocial/n ... ning-trike
However, this appears to be a wacky concept, whilst the 3 wheel Tmax looked to be a practical proposition. Same front suspension design as the 3 wheel Tmax. Still, rather like the combine backrest / topbox /panniers idea!
