Tmax CVT Recall
Tmax CVT Recall
Thinking back to the Recall back in Feb where new model Tmaxs were fitted with a new CVT - did this include fitting a new Vee-belt? (not to be confused with the other recall where a new final drive belt was fitted!)
For some reason my Tmax wasn't covered by the original recall, but I've now managed to get my Tmax included in the recall, by means of some hidden negotiations between the dealer and Yamaha, given the other problems I've had (4 months off the road after a bearing failure) and I've had lots of 'funnies' with the CVT.
The dealer wasn't sure if the kit came with a belt or not - I guess its worth paying for a new one even if its not included as the labour will be free and the current one is half worn anyway.
bugsy
Current Ride: X ADV 750
Re: Tmax CVT Recall
Post by bugsy »
I have to admit to being confused about these recalls. In March I contacted Yamaha Uk telling them I had had the drive belt and flash update recall but other owners had been offered CVT replacements too.
Yamaha UK told me that dealers were asked to check the CVT during the final drive belt replacement work. My dealer hadn’t a clue about this advice and just fitted the final drive belt and completed the flash.
I followed your sorry story since March and as I have previously discussed, I found the attitude of your dealer and Yamaha totally abhorrent.
My next machine will not be a Yamaha. I firmly believe they have lost their way and if they are not careful many potential buyers.
Re: Tmax CVT Recall
bugsy wrote: Fri Aug 09, 2019 6:25 pm I have to admit to being confused about these recalls. In March I contacted Yamaha Uk telling them I had had the drive belt and flash update recall but other owners had been offered CVT replacements too.
Yes, exactly the same in my case, I hadn't heard about the checking the CVT advice, and I suspect my dealer hadn't either! He's certainly never mentioned it, though he said he did check with Yamaha as to whether mine was covered by the CVT upgrade - especially as I previously been in there complaining about CVT issues (seeming to slip rather than drive when accelerating at high speeds, unpleasant metallic noises). When I got my Tmax back from the bearing failure issue, once it loosened up, it seems to be running fine - except that the CVT gremlins are still there - it works fine as long as you don't go above 5500 rpm or demand too much acceleration. I rang Yamaha Tech Support up to find out what problems the CVT upgrade was supposed to fix and why mine wasn't eligible when apparently similar ones were. The guy at Yamaha took some details and then suddenly became mysterious and told me to get the dealer to contact him 'for guidance', which intrigued the dealer immensely! It seems that discussions between the dealer and Yamaha took place over a couple of weeks and then the CVT upgrade became available on Yamaha's parts system for the dealer to order. I'm hoping that this will finally solve the issues.
My off-throttle surging issue (another long story in which no-one experiences the issues I report!) does seem much better (if not entirely cured) since the ECU upgrade / rebuilding of the scooter!
Although Yamaha haven't exactly covered themselves in glory, it must be admitted that with costs of the new final drive belt (£250 retail), a new CVT (£x00), and god knows what on the bearing failure, Yamaha have certainly not made any profit on my Tmax!!!
Re: Tmax CVT Recall
Yeah, definitely get a new belt Grumpy even if you have to pay for it yourself. It's a no brainer. It will save you loads and your bike will go nicely for the next few thousand miles.
EvilRacer329
Current Ride: Yamaha T-Max DX
Re: Tmax CVT Recall
Post by EvilRacer329 »
Hmm; that's worrying. The used Mk6 I've bought has had the final-drive belt and ECU recall, but this is the first I've heard of a CVT-based recall. My guess is that it's a "service bulletin" rather than a safety recall, and so they're not legally required to be proactive about it. I'll see how the bike performs on the trip and speak to my dealer when I return...
Nick
Re: Tmax CVT Recall
You could be right as it probably isn't a safety issue. I only heard about it on here - some owners were invited to have this CVT upgrade at the same time as the Drive Belt replace and ECU update (in Feb/Mar). It was said on here that a pulley was too soft and was bending, but that's all I know. My dealer HAD heard of it, but mine wasn't eligible (at the time) despite me complaining of CVT issues. I'll see what difference, if any, it makes.
tmaxrobbo
Re: Tmax CVT Recall
Post by tmaxrobbo »
my recall did include CVT final belt and ecu flash . It did not include the V belt . Mine had been slipping but they did not replace it . Once done the rumble from inside went . If getting it done pay the £100 or so for the new belt and reset the belt reminder . Good for 12000 miles then
EvilRacer329
Re: Tmax CVT Recall
So it's just a problem with some of the belts fitted from the factory? No other parts involved?
Nick
Re: Tmax CVT Recall
EvilRacer329 wrote: Thu Aug 15, 2019 5:55 pm So it's just a problem with some of the belts fitted from the factory? No other parts involved?
Belt confusion!!! There was a recall for every mk6 for the final drive belt (to the rear wheel) - the original design was too weak it seems, and some maniacs broke theirs! There was also a recall for some mk6s for the CVT mechanism (not belt), which mine wasn't eligible for at the time, though its being done next week.
EvilRacer329
Re: Tmax CVT Recall
Ah, I see. Keep us posted on the mechanism, what were the symptoms that indicated you had a problem with the CVT mechanism? It's a pretty simple piece of machinery, so I'm curious to know what's being changed...
Nick
