I've been looking at a very nice Kawasaki Vulcan VN900 Classic (2012) at a local dealer.
Has anyone had one of these and if so how did they find it?
Time for a bike change.
- 2wheelover51
- capitano
Re: Time for a bike change.
A couple of my old Club Brothers had VN900s. One had the Classic and one the Custom (the one with the skinny front anyway.)2wheelover51 wrote: Sat Mar 02, 2019 12:46 pm I've been looking at a very nice Kawasaki Vulcan VN900 Classic (2012) at a local dealer.
Great bikes, as are all the Kawasaki cruisers. As reliable as a stone doorstep, the stock ECU copes well with just a cold reset with an aftermarket exhaust (ie no need for a power commander or other ECU assistance,) and the V twin gives a lovely power delivery.
Kawasaki also gave the cables and wiring a decent length so that changing bars wasn't an issue. One of them had a small set of apes on and the other quite wide cruising bars.
They seem to fit a wide variety of body shapes and sizes too, as the ergonomics are generally very good. As said, bars are easily changed and the footpeg positions , to me at least when I rode them, were in a natural position.
they handle well enough compared to Harleys for example and not sports bikes, and the same can be said for the braking. Decent enough brakes for a cruiser but if you are jumping off an R1 they might feel wooden.
I seem to recall something had to be disconnected and possibly removed to reach the oil filter but the detail escapes me for now. Both owners maintain ed heir bikes themselves and they were easy to work on generally, like most Kawasakis.
Scootypuff snr
Test rode one at Kirkcaldy Kawasaki. Enjoyed the layout and build quality so why didn't I buy?? got a better deal on a Suzuki (as you do) but build quality wasn't the same.2wheelover51 wrote: Sat Mar 02, 2019 12:46 pm I've been looking at a very nice Kawasaki Vulcan VN900 Classic (2012) at a local dealer.
Like most cruisers I managed to scrape bits being enthusiastic but they have a good following (though I believe Kwak have dropped all cruiser models except the 650 now- engine sharing platform)
You won't get any respect from HD riders but hey that's not a bad thing
Take a test ride it will be enjoyable
- 2wheelover51
Well the dealer (Hawk Motorcycles at Melton Abbas) delivered it today and it looks like a nice bike. I only managed to ride it for about half an hour tonight but will be out with my tools and ACF50 etc tomorrow if the weather lets up. (storm Freda)
Scootypuff snr. Build quality looks good on the bike and it's one of the few cruisers I've seen with a fuel gauge and digital clock. It's also got 5 gears compared to the 4 of the Shadow, which was often a pain with the lugging issue they have. My mates Sportster 883 is far more flexible to be fair.
Capitano, interesting that you mention the aftermarket pipes. This one (2012 model classic) had a new set of Cobras on, but when the original oxygen sensors were connected it didn't run right. Apparently disconnecting the sensors made the bike run ok but the FI light came on after 15 or so miles. I got them to refit the standard pipes and it's running fine, but I may put the Cobras back on in the future. When you say cold reset do you mean the ECU should automatically adjust itself to suit the pipes? The dealer (Steve) said he'd been told he would have to fit new (different) 02 sensors. I suspected it might need a power commander/remapping to cure the issue. I did notice the decent length cables as well as I will probably be fitting a set of higher 'bars.
- capitano
Now you are asking me to delve back in time to actually working on at least 5 (maybe 6) VNs, the two 900s I mentioned, at least one each of the 1500 and 1600s and a VN2000. The VN900s were closest to my W800 in what we had to do so I'll try and be as specific if I can and apologise if I get it wrong. The 2000 was pretty specific anyway. It had a power commander when bought used, huge apehangers, and a darkside rear tyre!2wheelover51 wrote: Sat Mar 02, 2019 10:25 pm Capitano, interesting that you mention the aftermarket pipes. This one (2012 model classic) had a new set of Cobras on, but when the original oxygen sensors were connected it didn't run right. Apparently disconnecting the sensors made the bike run ok but the FI light came on after 15 or so miles. I got them to refit the standard pipes and it's running fine, but I may put the Cobras back on in the future. When you say cold reset do you mean the ECU should automatically adjust itself to suit the pipes? The dealer (Steve) said he'd been told he would have to fit new (different) 02 sensors. I suspected it might need a power commander/remapping to cure the issue. I did notice the decent length cables as well as I will probably be fitting a set of higher 'bars.
Of the two 900s, the most common problem when putting aftermarket pipes on was the popping and banging on the overrun. This was as much to do with the secondary air injection as with the incoming fuel/air mixture. Both bikes had it bypassed in some way. We did one by plugging the hose that goes to the ECU-operated valve from the airbox, leaving it all intact. The second we did by a similar method to my W800 by fitting plates that replaced the reed valves.
I terms of correcting the fuel/air mixture, the stock ECU did a pretty good job with the set of aftermarket pipes on one bike, with just a cold reset (I'll come to that in a bit,) and they may well have been Cobras. Definitely an off-the-shelf popular aftermarket system for the bike, though. The second one had a custom made set of short slashcuts that were so obscenely loud, one of the guys (who normally likes loud pipes) made up a simple set of baffles for them. They were still loud and pretty much straight through.
With the latter one, the stock ECU was on the limits of coping , especially when the bike was cold. It misfired a bit and was still popping and banging excessively on the overrun, and not in a nice-when-it-does-it-occasionally way. A power commender would have been better, but we got hold of a plug-and-play version of the Cobra FI2000 and used that. Brilliant little devices that override the CU adding more fuel at low/mid/high range, set by potentiometers. I ran one (meant for a Harley twin cam softail) on my W when I had some opened up HD mufflers on it, and no O2 sensor.
On the one with the aftermarket system, it ran well with the stock O2 sensors and a cold reset of the stock ECU. This was achieved in the following way:
1. With the engine cold, disconnect the battery, and leave disconnected for at least 30 minutes (the time it takes a Prospect to make tea, and everyone to drink theirs and finish their stories
2. Before reconnecting the battery, operate the brakes, horn etc, switch the ignition to on while doing this, then off again. This is to get rid of any capacitive or inductive voltage in the system. It might be snake oil but it works!
3. Reconnect the battery. Start up the bike and leave to tick over until it drops the revs (ie the ECU drops out of cold-start mode). Don't rev it.
4. Take it for a ride and the ECU will start to relearn the characteristics of the new setup. It may take a few rides to get there but it will improve over a short period of time.
(I used the cold rest on my W with a Motad aftermarket system fitted and it works perfectly with the stock ECU and O2 sensor)
On the VN900 with the open pipes, we took off the two O2 sensors and replaced them with eliminator plugs. You could make your own as I have the resistor values for the one I used t do the same on my W and that was a VN900 one originally. That one used more fuel overall than the one with the stock ECU/O2 sensors. hat was what we expected. The pipes that were made for it didn't have the bosses for the sensors anyway, but if you were doing the same with a stock or aftermarket system, a short bolt and copper washer do the trick.
We never used, nor even knew about, fitting different O2 sensors. That's not to say it isn't a valid option.
I hope this helps, because potentially you have a great bike there. I rode Harley Davidsons for 15 years and have no beef with them whatsoever. If I was returning to riding big cruisers though, I'd look no further than a used VN.
- capitano
An O2 eliminator plug, the resistor values, and a bolt/washer used to blank off the bosses where the sensor fits.
- capitano
- capitano
- 2wheelover51
Capitano, thanks for all the useful information. I've just unpacked a box which came with the Cobra pipes and it is indeed a couple of bosses, copper washers and the plug-in resistors which you've mentioned. I'm hoping that they fitted them but didn't try the cold reset which you describe. I have to admit I didn't realise the ECU was capable of relearning the fuel/air curve needed to give good fueling.
I'm going to print all of the posts you've made and keep them for future use. I will try the cold reset. At the mo' I need to alter the floorboard positions and/or adjust the gear lever and brake levers, as well as hacksawing about 2" off the 'bars. Then I'll ride it a bit more. I've also got to get my stethescope on the front head/cylinder and check out a quiet tapping noise I noticed when I rode it yesterday. With only 20k on the clock I doubt it will be a valve shim since that's only required at 26k. I'm thinking maybe the front cylinder chain tensioner is midway between clicks and might look at that. Steve at Hawk motorcycles who sold me the bike said they'd do any work to make sure I'm 100% satisfied, but I do like to tinker myself (provided it doesn't nullify the 3 month warrantee) In fact these days I tend to tinker and polish more than I ride...
No chance to do anything to it today thanks to storm Freya..
