Urgent help / advice required please.
Left my Burgman 650 (2012) for less than an hour. When I came back I had a bit of difficulty releasing the seat at first to put some stuff in. Then I found the key would not turn the ignition to the on position.
I can turn the key between lock, and parking light lock - it will not turn any further clockwise from these positions. It seems to be a little looser and wobbly in the barrel than normal.
The steering lock is not engaged despite the barrel being in the 2 locked positions. Sometime there is a slight clunk when jiggling the key hard between these 2 positions.
I've only had it a month and everything has been perfect until now - the keys worked fine to start and lock the steering. I don't know if I could have turned it to the lock position and removed the key without fully turning the steering left, or if it was an aborted theft attempt by filthy scumbags who broke the steering lock and ran away (there was no other evidence of attempted theft).
Really need some help and advice about what it might be and how to go about fixing it, as I'm away from home and stuck.
Parts diagrams or schematics would help so I can understand how the lock works, and any links or pictures of what needs to be removed so I can access it to inspect for physical damage would be great. I know my way around a toolbox but I'm new to bikes and particularly all the plastics involved on this one.
Are there any UK specialists in this sort of thing or is it only Suzuki dealerships who can work on them ?
Thanks,
Alan
Urgent Help / Advice - Suzuki Burgman Ignition + Steering Lock
Re: Urgent Help / Advice - Suzuki Burgman Ignition + Steering Lock
PS - sorry for posting this in the intro section .... it was the only part of the forum that showed up when I registered.
Newbie mistake.... Fairly new to biking. Only got the Burgman a month ago to tow behind my 6.5 ton motorhome that I live in, in UK and Europe....
- Waldorf
Hello and welcome!
I can't help with the problem but know someone here will have the answer.
- muddyfox
Welcome parapilot. You could try looking through these links from this forums Burgman owners section:-
http://www.maxi-muppets.co.uk/forum/sea ... %5B0%5D=49
Muddyfox (Nottingham)
Ride safe
Ride safe
Welcome Alan
6.5 ton is quite a large beast
Whereabouts are you at present as I think I still have a Suzuki dealer directory (they used to give them with the bikes) covering all of Europe.
Dealer won't charge to look & might point you in right direction.
Robinson's Foundary used to show schematics but don't recall it covering body panels (just looked doesn't cover Burg 650)
Does this help
Does this help
Schematics & part numbers here bud >>>>>>>>>>>>
https://www.cmsnl.com/suzuki-an650a-bur ... DHX082nzIU
- Current Ride: Forza 600
We seem to have a problem - hence me using a test account. 3rd post
mottza_test wrote: Fri Jan 25, 2019 11:07 am We seem to have a problem - hence me using a test account. 3rd post
FixedParapilot wrote: Sat Nov 03, 2018 9:25 am PS - sorry for posting this in the intro section .... it was the only part of the forum that showed up when I registered.
I like the idea of your Forza 600 bud
