Slight vibration when pulling away slowly
rayb
Current Ride: Honda SH300
Post by rayb »
I'v just noticed a slight shudder from the front wheel if I pull away slowly. It's only for a second. Possibly does it when I go faster but it's not noticeable. I can't see anything obvious.
Re: Slight vibration when pulling away slowly
Check the ABS sensor and ring gap, front wheel bearing, brake pads and disc. Have you hit a sleeping policeman too hard.
Snackered Ray, i will give you 50notes for it and chance being bit :lol: :lol: :lol: :lol: :lol:
rayb
Post by rayb »
Dave Weller wrote: Fri Aug 03, 2018 5:53 pm Check the ABS sensor and ring gap, front wheel bearing, brake pads and disc. Have you hit a sleeping policeman too hard.
ABS, that's a thought. Thanks.
rayb
Post by rayb »
kayz1 wrote: Fri Aug 03, 2018 5:55 pm Snackered Ray, i will give you 50notes for it and chance being bit :lol: :lol: :lol: :lol: :lol:
I'll take the notes if they're hundreds :)
Ralph
Post by Ralph »
If your sure it's from the front brake pistons sticking.
Ralph
Nr Fleetwood
rayb
Post by rayb »
Ralph wrote: Fri Aug 03, 2018 7:51 pm If your sure it's from the front brake pistons sticking.
Presumably, I could check that by not using the front brakes and seeing if it goes away?
Ralph
Post by Ralph »
Put it on the stand get someone or use something to get the front wheel off the ground and see if it spins reasonably easy,
there is often a little drag but you should be able to turn it easily.
Ralph
Nr Fleetwood
Scootypuff snr
Post by Scootypuff snr »
warped disc??
apply brake disc cleaner ride up road grab a handful do several times to ensure even coverage ( though remember what comes off the disc must stlick to the pad for a short while at least)
rayb
Post by rayb »
Scootypuff snr wrote: Sat Aug 04, 2018 9:05 am warped disc??
That seems to have done the trick thanks :)
