Dont use keyhole shutter
ridinhigh
Current Ride: GTS 300
Post by ridinhigh »
Hi all,been reading burgman posts,i see a problem some owners have had with the key hole shutter,
some owners say they don't use it any more.
so how do you keep it open ,?
Whatsisname
Current Ride: Burgman 400 K5
Re: Dont use keyhole shutter
Post by Whatsisname »
You have to slide it sideways across the hole to block it, it's not sprung or anything, just don't close it.
Steve_D
Post by Steve_D »
Whatsisname wrote:You have to slide it sideways across the hole to block it, it's not sprung or anything, just don't close it.
Don’t you have to use the special key to do that? IIRC you can close it with any key but you need the correct key to open it. Been so long since I had mine I can’t remember now. I do remember coming unstuck using it. :(
Honda SH300i
muddyfox
Post by muddyfox »
Muddyfox (Nottingham)
Ride safe
Luckydave
Post by Luckydave »
You can only close it with the unique to your bike key,don’t close it and you won’t have a problem opening it
ridinhigh
Post by ridinhigh »
It closes it self as soon you take key out
Is this a new thing then ! i have had 5 or 6 Burgman scooters and never had a moments trouble with the shuttery thingi-me-bob.
Lyn.
Stephen
Post by Stephen »
ridinhigh wrote:It closes it self as soon you take key out
No it doesn’t,it has to be shut with the key....
Steve
Honda Forza 350
Ride Safe Ride Upright
Stephen
Post by Stephen »
kayz1 wrote:Is this a new thing then ! i have had 5 or 6 Burgman scooters and never had a moments trouble with the shuttery thingi-me-bob.
Lyn.
Neither had i any problems on any of my many Burgmans until earlier this year,i still think its a very good extra bit of security,guess i was a tad unlucky,
Steve
Honda Forza 350
Yes Meldrew Sir, the Kawasaki J300 ( Kymco ) i have has the same thing. The only difference i can see is that to close it you use a little yellow button on the slot outer rim to open it the same as the Burger, the back end of the key.
Lyn.
