New season didn't start well C41 - FUEL PUMP CONTROL SYSTEM
Deleted User 5490
Post by Deleted User 5490 »
All.
So new season , health back to normal ( heart scare wasn't heart) and I thought it would be good to get the bike out.
Washed it, charges it , put new fuel in and started first turn ( as usual ) , took it for MOT , passed with minor advisories RESULT !
Then pulled into a pub to buy tax online and went to start it again and it wouldn't start. FI was lit up :( .
Breakdown came and put some jump leads on it (I had killed the battery by then) and away it went :) . Wrote it off to spending a winter in storage and possibly the washing it .....
Later in the week went for a 50 mile run , all good except just for 1 second , I lost power then back to normal .
still good.
Next day took it to work and at end of day, the FI was back . Grrrrr.
I got the code C41 from the dealer mode thing and need to know what I should test first.
Any people with this fault? Is it Common?
Any help would be appreciated.
Cheers
The Bern
Current Ride: Silverwing 600
Re: New season didn't start well C41 - FUEL PUMP CONTROL SYSTEM
Post by The Bern »
Accoring to LeDude, it's your fuel pump relay, see ............
https://284fd781-a-62cb3a1a-s-sites.goo ... edirects=0
Have wheels, will travel :D
Deleted User 5490
Thanks. Will spend my lunchtime pulling bits off . I think there is some talk of battery being slightly too weak ? So will start with jump leads
Ralph
Post by Ralph »
If you hear the pump prime when you turn it on the relay must
be working at that point at least.
Ralph
Nr Fleetwood
