Nc 700 x
alp231
Current Ride: X max 300
Nc 700 x
Post by alp231 »
I have seen one of these for sale going to look at weekend are there any downsides to ownership service costs etc
Re: Nc 700 x
Chain drive!
Symcity
Re: Nc 700 x
Post by Symcity »
I doubt whether you’ll have any problems with the nc700 - easily serviced by yourself - check for signs of droppage I.e bent levers etc - check condition of tyres chain and sprockets - preferable with centre stand and low milage with one owner - best of luck
TJSCOOT
Re: Nc 700 x
Post by TJSCOOT »
I bought a new un in 2012, had 5 years of mega reliability - only normal service stuff ever needed over 25k miles. Over that time did well in excess of 10k miles of touring in Spain, France, Germany........ never missed a beat sipped petrol at an average of 80mpg and managed just over 100mpg pootling around some French D roads - mate on his GS1200 was just managing 50mpg until the Beemer broke, again !!!!!!! Pretty simple to service yourself, even the valve check is simple spanner adjustable. I fitted an auto chain oiler and the OE chain ( a known weakness) was still OK when I changed bikes. Excellent bike
Taipan
Re: Nc 700 x
Post by Taipan »
DCT version? Increasing number of these have shifter pin failures. If you get -- in the display instead of D or S, then walk away as it can cost a few hundred to fix. The 750 is not affected by this.
Re: Nc 700 x
Early NC700X had a recall for the chain, The RG chain fitted (stamped on the side plates) to some bikes should have got changed to a DID chain. They changed my one free of charge, because I chased them up on it. It is a good bike, simple to work on and well made.
charles1976
Current Ride: shopping around
Re: Nc 700 x
Post by charles1976 »
My nc750x dct just just under 1 year old...faultless and very good motorway cruiser too...recommended....
Re: Nc 700 x
Taipan wrote:DCT version? Increasing number of these have shifter pin failures. If you get -- in the display instead of D or S, then walk away as it can cost a few hundred to fix. The 750 is not affected by this.
Ow No They Don't ;)
It was the early 2012 model and mainly the Integra..
Lyn.
Taipan
Re: Nc 700 x
Post by Taipan »
Ow No They Don't ;)
Lyn.
Hmm, I only know of X's with the problem, but assumed it affected all the 700 range? I'm told Honda mechanics see a fair few of these problems and get the feeling this is under publicised really. I assume the part was modified for the 750s as there have been no such problems with those? Doe 2012 onwarsd have a modified part?
But I suppose given the numbers sold and the high mileages achieved by a lot of them, its not that much of a porblem? Cracking bikes either way. 8-)
Current Ride: gb 350s
Re: Nc 700 x
I had a problem with a 700 integra dct, it stuck in 2nd gear. :(
