400 k8 bleeding brakes
keithy
Current Ride: Raptor 1000
Post by keithy »
Hi got new brake pads and want to change fluid what caliper do you do first left or right ?
The brakes are not linked
Thanks K
Re: 400 k8 bleeding brakes
I remove most of the old fluid from the reservoir first, fill up and then start bleeding, starting with the longest pipe run, don't create air leaks and pump through until you have new fluid showing in the clear plastic pipe you fitted to the brake nipple.
StephenC
Current Ride: Kymco DT X360
Post by StephenC »
Ah, a technical question. At first sight I thought it was going to be a criticism....
Can is not the same as Should
On the combined nraking they always state do rear first then do front combined firsr
I use a non return valve in middle of clear tube which feeds into a 500ml plastic fanta type bottle. Just pierce hole thru lid. That way you can just pump the brake lever an add fluid. And just watch the bottle .
You can get the non return valve off ebay for £3 item number 302004324070 and then get a used bottle for the end
keithy
Post by keithy »
Thanks for the reply's the k8 does not have linked brakes
Apparently do the caliper furthest from the master cylinder first
Will do them on sunday
Thanks Again
stevew
Current Ride: Maxsym 400i
Post by stevew »
If the brakes are not linked it surely doesn't matter which one you do first as they are completely independent of each other???
How can either have any influence on the other one ?
Orpington, UK
2014-Honda Wave 110i
2013-Sym Maxsym 400i
keithy
Post by keithy »
the k8 has twin disks on the front
schwalbe
Current Ride: Burgman 400 K9
Post by schwalbe »
On the K8 the front and rear brakes are independent of each other. The left lever works the back and the right the front. When I changed from my K2 I spent six months just using the left lever and thinking how crap the brakes were.
