Gopro mount
Scootles
Current Ride: Vespa GTS 300
Gopro mount
Post by Scootles »
I see from searching that cameras have been discussed before, but it's the mounting of a Gopro I would appreciate your views on.
I mounted mine on the left side of the fairing, and to get the view I wanted I used the Gopro three way mount which has a couple of links in it. The video produced has quite a lot of vibration on it, possibly amplified by the mount. I wondered if it is better to mount the camera direct onto the fairing and just level the camera by getting the mount level.
Also, I believe some people use a suction mount and I wondered if this vibrates.
I hope the above makes sense. Basically, how do I minimise vibration (apart from avoiding the Cumbrian road surfaces)?
Re: Gopro mount
P.M Syntec4 (Lee) he is your man he can put you right,
frankiej1949
Re: Gopro mount
Post by frankiej1949 »
I mounted my drift onto the fairing om my 650 Burgman and found it to be a really stable pic.
phil y
Current Ride: Burgman 400 + van van
Re: Gopro mount
Post by phil y »
Mine is mounted on the screen and pics are ok
Phil
Steve_D
Re: Gopro mount
Post by Steve_D »
Here's mine mounted on my FJR. I mounted it exactly the same on my Burgman although I seem to remembering applying a thin bead of clear silicon sealant between the fairing and headlamp lens to stop a bit of vibration.
Honda SH300i
Scootles
Re: Gopro mount
Post by Scootles »
Thanks everyone. I'll be trying the Steve D method next, when I get hold of another self adhesive mount. I tried a suction cup which had a very strong hold on the front of the screen, but there was still more movement than I would like. The actual camera mount can move a little relative to the suction cup, and this allowed more vibration than I would like. Perhaps aim being fussy, but I've seen the same type of camera on my sons bike and it was much smoother. Perhaps the larger wheels of a bike and perhaps better suspension make for a better platform. The fight goes on ........
Re: Gopro mount
I had best results with mine mounted on chest or helmet. My body soaks up most of the vibrations. Having a lot of flabby body fat helps too :)
Re: Gopro mount
same here i have them on three helmets, depending on the front vent of helmet type you can have them there also.. i use curved mounts on the helmets and i you dont mind waiting a couple of weeks i use this supplier at 99p delivered for two http://www.ebay.co.uk/itm/2X-Curved-Sur ... 2a4c236155
or flat mounts same here http://www.ebay.co.uk/itm/2X-Flat-Mount ... 3aab482fa6
i also use a tether http://www.ebay.co.uk/itm/1pc-Camera-Te ... 4ade920bab
my son uses the chest mount for paint balling and target shooting £6 here in uk http://www.ebay.co.uk/itm/Adjustable-Ch ... 567549be82
Re: Gopro mount
ouch! That chest mount's damn cheap... I dread to remember how much i coughed up for the gopro branded one :(((
Re: Gopro mount
halfabusa wrote:ouch! That chest mount's damn cheap... I dread to remember how much i coughed up for the gopro branded one :(((
well its been in use a year, looks same as his mates go pro one, if you dont mind a wait.
