Ram Mount for 2013 Burgman 650
sitrap
Post by sitrap »
Have new Tomtom Rider 400 satnav I picked up at the gadget show this weekend, comes with a Ram Mount, but need a base for the Burgman. Ram-mount website says the brake reservoir version is not suitable for 2012/2013 650s. No alternative mentioned. Any ideas ?
Steve_D
Re: Ram Mount for 2013 Burgman 650
Post by Steve_D »
When I had my 2011 Burgman, I mounted a suction base disc on the flat part of the top of the dash. I then mounted my setup onto that with a suction fitting the same as you would use for a car windscreen. I used a tethering cord in case it came loose but it never did in all the time I used it.
Honda SH300i
i think kayz1 has made a brake reservoir version with many holes for various reservoir top situations
Post by Bluebottle »
KayZ1 is your kiddy, but I think he is away on an adventure at the moment, have a search of his posts for details.
I did mine before I met him, from these people - cheaper than RAM but fully compatible if you order the same ball size.
There site is http://www.ultimate-mobiles.co.uk
I chose a stalk mount
same people i got my triple tree ball mount from good service
maccecht
Current Ride: 650
Post by maccecht »
I made one from a bit of flat SS just drilled it to fit the Reservoir bolts and fit the Ram mount.
spaceprobe
Current Ride: Maxsym 600i ABS
Post by spaceprobe »
I use this one on the SYM with my Rider 2 and you can see its got lots of options re the screws so are you sure it wont fit?
http://www.ram-mount.co.uk/reservoir-co ... -1567.html
Gerard C
Post by Gerard C »
I've got that same mount Mr Probe. Used it on my 2010 and on the 2014 650's.
Scootles
Current Ride: Vespa GTS 300
Post by Scootles »
Just fitted the Ram brake reservoir mount on my Burgman 400 today. I could have used the slots at the edge of the mount, but in the end I drilled an extra hole on the centreline to suit my reservoir. Looks pretty tidy and secure.
bornagainbiker
Current Ride: Honda Forza 300
Post by bornagainbiker »
I just used and still use my supplied TomTom suction screen mount or my waterproof case with a screen mount suction adaptor. The B650 screen is fairly flat and as yet neither has fallen off, even tested down several cobbled streets but I do have a safety cord attached just in-case.
