Exhaust grinding on concrete
burger uk
- Current Ride: Big burger aka the armchair
when I bank the old girl over the exhaust downpipe grounds out and it pops fire out on the overrun [THUMBS UP SIGN] it's good fun and I love riding it
MT606
- Current Ride: burgman 400 c90
Re: Exhaust grinding on concrete
I do the same with mine but it's usually the centre/side stand and rear drive casing, can't get my toe down mind, no matter how hard I try, I miss my aprilia.
burger uk
My aprilia was lovely but the burgy is so stable and usable it's a superb tool that ticks all the boxes apart from "flash Harry" attention which I like, it's good to be different [THUMBS UP SIGN]
- Jimo
- Current Ride: 92 Helix
A rider that causes a Burgy's exhause to scrape the ground truly doesn't deserve to ride a Burgman... Undoubtedly he (she?) should take a course in proper motorcycle riding and control.
Jim
Jim
burger uk
Leaning it over causes this to scrape going slower would eliminate this but I don't want to sometimes
Well done that man that's what the Burger is made for.
- Steve_D
- Current Ride: Honda SH300i
Put the rear shocks up to max and that will give you more clearance.
Honda SH300i
Honda SH300i
If it is shock trouble you have then get a pair of Fornalles Air shocks...fantastic difference in comfort and handling.
Lyn.
Lyn.
- horobags
I disagree , its up to the riders expierience how far he wants to go , on a bike or a scoot. Maxis have good lean angles with good tyres fitted. The exhaust which is grounding out ( above) is an aftermarket can which might have less ground clearence making it easier to touch down.Jimo wrote:A rider that causes a Burgy's exhause to scrape the ground truly doesn't deserve to ride a Burgman... Undoubtedly he (she?) should take a course in proper motorcycle riding and control.
Jim
- Jimo
When an exhaust, or part of it hits the ground, apart from sparks, things can fall off.... Unlucky for you if you're following and get hit; do remember that it is an offence to have insecure objects on a vehicle - it doesn't have to be a lorry, it can be anything that uses a road.
Jim
Jim
