Lyn.
Modern bikes !
Modern bikes !
Last week my local KTM/Honda dealer asked me if i would have a look at a 990 swing arm, so they drop it off and i take a look. The Teq went to adjust the axle/chain and the axle adjuster bolt ( stainless into Ali swing arm ) the head broke off. So now we have a 65mm long stud into the Ali arm and no way to get a stud extractor onto it as the adjuster block is in the way..
weld a long nut to the stud and try to unscrew it with a long socket, after lots of heat ( hot air gun ) and WD40 plus oil left upside down over night, it came out.
well guess what arrived today! another two
all these bikes are JUST out of warranty..Don't forget to pull the adjusters each year and lube them...told him to get a spare from a breaker to have in stock. The last one is going to cost them as i had to drill the stud out, two Cobalt drill bits cost £14 then i had to make a Lonnng drill bit so as not to hit the adjuster block with the drill chuck....got to be lots of brownie points in this.
vors sprung dork
Lyn.
Lyn.
Hughie
- Phils Gimp
- Current Ride: No scoot at the moment
Re: Modern bikes !
Good advice about removing and lubing. YZF-R125's can be very prone to this. Never failed to get one out yet with the use of a hot gun and some 'black magic' Link
It's often overlooked but a few minutes spent removing and lubing can save hours later.
OnlineDave Weller
- Current Ride: Forza 125
Re: Modern bikes !
If your shelling out the full Jap price for a bike, you need to know where they are made, IMHO.
Re: Modern bikes !
Had similar on an FZR400 chain adjuster bolt in a swing arm, although seemed to have an insert in the alluminium...
I always remove the bolt and coppa slip em before putting em back...
Re: Modern bikes !
Hughie wrote:Good advice about removing and lubing. YZF-R125's can be very prone to this. Never failed to get one out yet with the use of a hot gun and some 'black magic' Link
do you have to buy that Black Magic in bulk Hughie? no prices on the site and say they will give you a quote.
Does it work as they say?
Lyn.
Hughie
- Phils Gimp
Re: Modern bikes !
We buy it from a company called FÖRCH.We can buy individual cans of it as far as I know. Even the Wurth rep says it's good and that they have nothing like it.
I never use anything else for seized bolts etc. Maybe you can see if you have a local rep in your area that will let you buy 1 can to try before you place an order.
They also sell the only product I have seen that can actually deal with really manky old fuel deposits in carbs,it's called 'system engine cleaner'. I don't breathe it in if I can help it or get it on my hands but great stuff.The only 2 products we buy from them,the rest comes from Wurth.
Re: Modern bikes !
Hughie wrote:We buy it from a company called FÖRCH.We can buy individual cans of it as far as I know. Even the Wurth rep says it's good and that they have nothing like it.
thanks again Hughie, the lad has a garage so i will get him to check out the availability.
Lyn.
