Can you use acf-50 on exhaust pipes?
masterchop
Current Ride: Burgman K3 400
Post by masterchop »
Or would the heat just burn it off?
Single cylinder rumbler
Re: Can you use acf-50 on exhaust pipes?
Yes... :lol:
Yes you can BUT yes the heat will burn it off...
masterchop
Thought as much
BBQ paint
I've used bbq paint a few times, ok on silencers but hopeless on downpipes.
masterchop
Yep I've tried BBQ paint before. Agree. Not good for down pipes.
I use acf on zorsts, it does burn off but not 100% as it still protects. If its a black painted mild steel can id rub down, paint with killrust, then halfrauds high temp black paint, and a coat of acf to finish. :geek:
larryblag
Current Ride: Honda NC750S
Post by larryblag »
Or B&Q paint ;)
Previous bikes, many and varied. Last: KAWASAKI J300 SE
Killrust will stop the paint bonding.
you can buy manifold paint for cars perfect for downpipes and take heat upto 1000 degrees
