Motorcycle ABS - Anti-lock Braking System Video...
anonstarter
Current Ride: Pending
Post by anonstarter »
A brilliant example of how ABS differs from non ABS on a motorcycle in 'slippery' conditions.
[BBvideo 560,340][/BBvideo]
Should ABS be mandatory on new 'motorcycles? Is it survival of the fittest - or is it now survival of those who know better and can afford it?
Re: Motorcycle ABS - Anti-lock Braking System Video...
great vid... never had abs on a scoot but when you see the difference it tends to wake you up to how you should proceed to be more careful in not locking up your brakes, generally i try and leave a bigger gap than some in front so i can react better .. getting old :D and rear combined first then front brake.. i do this so if i would need to react in a split second, i would not grab the front first in brain panic and lock it up... just my way of thinking and im sure we all do it differently :D
StephenC
Current Ride: Kymco DT X360
Post by StephenC »
anonstarter wrote:Should ABS be mandatory on new 'motorcycles? Is it survival of the fittest - or is it now survival of those who know better and can afford it?
That horrid, nasty EU has already made it mandatory for everything sold in Europe over 125cc to have ABS from 2015, I think. (It might be later, can't be bothered to check right now).
Which is why we are starting to see a lot of scoots get it already.
Can is not the same as Should
R1K SU
Current Ride: Burgman 650
Post by R1K SU »
Great vid, but even better is one of the vids on the tile wall afterwards R1 chasing R6 :)
Yam RD350 YPVS
Honda VFR750
Yam RD 350 air
Kawa GT550
Kawa ZZR600
Yam FZ1s
Burgman 650
Suzuki GSXS1000
Suzuki GSXR1000 K7 😜😜
Zero FXS
Yes.
Next question please.
stollie
Current Ride: YP250
Post by stollie »
Very good video and yes every maxiscooter should be made with abs even paying a little bit more for safety. If it means coming out of a situation with hardly anything wrong with you then a little bit more money for abs the better. 8-)
Ferrit
Current Ride: MP3 400ie
Post by Ferrit »
Not a great vid as he clearly locks up the wheels deliberately. And don't get me started on why learning to brake is better than relying just on ABS. ABS is fine in the correct conditions, crap in the wrong one. ABS is not the cure all it is sold as. It is another assistance which needs to be understood and used correctly.
2013 Mp3 500sport
2007 MP3 400ie
A less than Civil Servant
Herts & Beds SERV
Ferrit wrote:ABS is fine in the correct conditions, crap in the wrong one.
Could you explain what the wrong one is please?
Post by Bluebottle »
Yes, next question please :lol:
On any loose sustrate would be the most obvious case.
stollie
Current Ride: YP250
Post by stollie »
Yes i would like to know the wrong one as well just like gn2 and probably a lot of others also. 8-)
