Cheap ebay givi style top boxes
Those 40 litre £30 delivered ones with plate just a warning mine came off on a bumpy road and went skidding across road .Box survived with just scuffs didnt burst open so boxes are strong just the bit where it clics on .Just added a bungy for rest of trip and it was fine .Jaz says its happened to a few on c90 forum as well we did have it on video but mike wiped it by mistake
						- MjW
 - Current Ride: TMax 2009 ABS
Re: Cheap ebay givi style top boxes
Yikes!
Was it within the max. load figure?
 WE ARE THE BURG   resistance is futile
There wasnt any heavy stuff in it no just been in garage its got "adlo 992" on plate or something like that .If I had been on my own would have lost box as only felt a bump and we were on rough north devon roads so had a few bumps so wasnt anything out of ordinary
				sad vampire
The ones with a metal baseplate require a little bit of adjustment to make them secure (bending the baseplate a little makes the attachment points tend to spring together, securing the topbox more securely & stopping it from rattling around).
The boxes themselves are ABS plastic & the locks are identical to the Givi ones (I'm using a Givi locking plate on a chinese clone box), so they're just as tough. Where they differ is in the baseplates, hard plastic ones that don't flex on the Givi, thin steel ones on the clones. Bracing the base plate with some angle iron soon sorts them out.
				sad vampire
Have a look at the metal bit that sticks up from the plate, it may need a slight bend to make it secure properly, mine did. Also have a look at the locking mechanism in the base of the topbox, is it springing back properly?pikey wrote:Mines a metal one bolted flat on top of a givi plate
