Piaggio Zip 2008 4 stroke help please
Hi , my neighbour, only young has just got a Piaggio Zip 50cc 2008 4 stroke, he asked about oil change, i cant seem to find the amounts used etc for engine oil or gearbox oil, cant find an online workshop manual, can anyone advise please cheers in advance
- StephenC
- Current Ride: Kymco DT X360
Re: Piaggio Zip 2008 4 stroke help please
You might find the right info either under Zip or Liberty here: http://scootercommunity.com.au/files/default.aspx" onclick="window.open(this.href);return false;
Can is not the same as Should
- ridinhigh
- Current Ride: GTS 300
here you are mate, from my haynes,book, engine oil 5w40 quantity 850cc gearbox 80W90approx 80cc
sppark plug champion RG4 OR RG4 HC
any thing else just ask
thank you both, thats brill i have both the oils as use them for my nexus, will have to get the syringe out for his gearbox oil
cheers
thank you again, need another answer please, he tells me speedo not working! can you point me in the right direction... 2008 zip 4 stroke..
not sure if its electronic end down to the speedo drive on the wheel , i had a quick ganders at ebay and saw this
http://www.ebay.co.uk/itm/Piaggio-Zip-2 ... 1397584%26" onclick="window.open(this.href);return false;
not sure if this is the type cheers in advance
- ridinhigh
the white plastic bit goes to speedo head and some times come unclipped, check it first
then have a look atfront wheel to see if cable screws into housing ,that also can break
best of luck
best of luck
thanks ridinhigh will have a look for him, cheers for your timeridinhigh wrote:the white plastic bit goes to speedo head and some times come unclipped, check it first
best of luck
