Tmax mk3 exhaust hole ?
007tmaxer
Current Ride: TMAX MK3
Post by 007tmaxer »
I thought I had a hole in my MK3 Tmax exhaust so I purchased a second hand exhaust from ebay and to my horror is also has a small hole at the base of the silencer ! its like a measured leak you can feel it with your hand when its running?
Any idea why i do not remember the MK1 & 2 having a hole it the silencer!
Any one need a mk3 exhaust??
Regards
Steve
phantom309
Current Ride: nc750sa
Re: Tmax mk3 exhaust hole ?
Post by phantom309 »
water drain hole...
I'll have to check my mk4 exhaust now! How big exactly is the hole? and where is it exactly? Presumably this isn't where the lambda sensor fits?
007tmaxer
Post by 007tmaxer »
MrGrumpy wrote:I'll have to check my mk4 exhaust now! How big exactly is the hole? and where is it exactly? Presumably this isn't where the lambda sensor fits?
The hole is about 3 to 4mm and its at the bottom of the big silencer and no not the Lamba hole!!
newscooter
Post by newscooter »
Is it there to let water from condensation, washing etc. to drain out ??
I can't see one on my mk4...
tmaxrobbo
Post by tmaxrobbo »
None noted on my as new origonal system I refitted after selling the Akra and bike
