Accessory Socket 650 exec
Noggin the Nog
Current Ride: Suzuki Burgman 650 Executive
Post by Noggin the Nog »
Will not be getting my new exec until April, but can someone tell me if the accessory socket remains live when the ignition is off or not ?
Just wondering if you can charge your phone or gps up whilst not riding?
Cheers,
Noggin.
Re: Accessory Socket 650 exec
Must say I'm not sure and as I no longer have mine I can't go and check, but sure someone else will answer soon enough.
One thing you may find useful is this 3-way extension as it has side-mounted cable so the plug fits and allows the door to be closed, there's also one with a USB output too.
http://www.ebay.co.uk/itm/330434829546? ... 3825wt_954
Noggin the Nog
Cheers for the tip Bud, as it will only be needed for my phone and gps, I'll be going down the usb route. ;)
Noggin.
Only live with the ignition on.
Not live with the ignition off.
To use optimate, you will need to run a lead from battery terminals.
Noggin the Nog
Thanks Dave :D
G.
bornagainbiker
Current Ride: Honda Forza 300
Post by bornagainbiker »
The charge socket is live from the Ignition only.
I have posted on the burgmanriders site how I resolved my sat nav via usb charging issue from the socket which is stupidly too close to the door when in use.
Please note I advise getting a 2000mah mini usb adapter which are only a few pence more as certain devices draw more current and then will not charge successfully.
http://burgmanriders.com/forum/accessor ... =3&ret=all
Noggin the Nog
Already read your post, good bit of info, will be getting these for the phone : http://www.maplin.co.uk/universal-in-ca ... tor-591370 and http://www.ebay.co.uk/itm/USB-male-righ ... 4aadc68fb1
Will be hard wiring the gps to the rear of the accessory socket.
Thanks,
G.
bornagainbiker
Thanks Noggin. If you are getting the cable from China via ebay you might as well save more money and also get the Mini usb adapter for only £2.85 from a UK ebay source..... http://www.ebay.co.uk/itm/Black-Mini-US ... 1645wt_952
Noggin the Nog
Cheers Bud :D
G.
