New Xmax 300
2wheelover51
Re: New Xmax 300
Post by 2wheelover51 »
"err pretty sure aluminium doesnt rust.... its steel you have to worry about." Quote All four inches.
Ha. From the moment metals are dug out of the ground they're trying to get back in! Especially when they're on motorbikes in the middle of winter! :)
Ralph
Re: New Xmax 300
Post by Ralph »
2wheelover51 wrote:"err pretty sure aluminium doesnt rust.... its steel you have to worry about." Quote All four inches.
Never was a truer word said.
:D
Ralph
Nr Fleetwood
Re: New Xmax 300
:lol: I like that one. True.
all-four-inches
Current Ride: 2013 T-Max 530 BlackMax
Re: New Xmax 300
Post by all-four-inches »
:D
but... its not true... :|
Aluminium is very corrosion resistant by default, with very little treatment needed.
Ralph
Re: New Xmax 300
Post by Ralph »
Ok it is corrosion resistant but it does oxidise, this than helps protect
it even further from corrosion, it still looks naf though.
Ralph
Nr Fleetwood
Re: New Xmax 300
Ralph wrote:Ok it is corrosion resistant but it does oxidise, this than helps protect
Until in the case of cars/motorcycles or any thing else that electricary is running through, add the salt on the roads and general crap and what does that give you! I will let Data/Bern and Mr Bluebottle do the teqi stuff.
The Bern
Current Ride: Silverwing 600
Re: New Xmax 300
Post by The Bern »
For a start there is that wonderful chemical reaction called bimettalic(aka galvonic) corrosion, you know the stuff that locks bolts into casings as if welded.
Have wheels, will travel :D
Ralph
Re: New Xmax 300
Post by Ralph »
600 mile service today only slight problem was the oil service light had not come on
at 602 miles so they could not reset it, it came on on the way home at around 620
miles which would be close to the 1000 k service of the km bikes so it likely counts
in them no problem reset it myself, now got a extra 900 revs does not sound a lot but
pushes the speed up to 50/55 and stops mos drivers from driving close, hell it was
cold early on,
Ralph
Nr Fleetwood
Mr Xmax
Current Ride: Xmax 300
Re: New Xmax 300
Post by Mr Xmax »
I had the same - service light came on for me at 620 for some reason. The extra revs really make a difference.
If the bike wasn't already white it would have looked it after my ride to work today from all the grit! Acf-50 on order!
Re: New Xmax 300
Ralph wrote:600 mile service today only slight problem was the oil service light had not come on
Do what? Why couldn't they? If its anything like the Tmax, its just a couple of button pushes, and the manual says to do so if you change oil early!
