Piaggio X 10
- frankiej1949
Re: Piaggio X 10
Thanks and a pleasure Michael. I did add some tags but they are not showing up. There was no reference to it being a 500 so I found some Fiat 500 decals, look quite discreet, lol.
Re: Piaggio X 10
them 500 graphics look good.. do you know what plug reference the scoot usesfrankiej1949 wrote:Thanks and a pleasure Michael. I did add some tags but they are not showing up. There was no reference to it being a 500 so I found some Fiat 500 decals, look quite discreet, lol.
- frankiej1949
Re: Piaggio X 10
I have a couple of these waiting to go in. AOR14LGS Brisk High Performance Motor Cycle Special Silver Electrode Spark Plugs
Re: Piaggio X 10
i wondered who bought 2.. i thought funkycowie might have made the plungefrankiej1949 wrote:I have a couple of these waiting to go in. AOR14LGS Brisk High Performance Motor Cycle Special Silver Electrode Spark Plugs
- frankiej1949
Re: Piaggio X 10
I put them in as soon as I got the 500 but I took them out after a week and went back to the NGK's to see the difference. Also thought the cvt and clutch needed to settle in too. I will put them back after its first service tomorrow. Will keep you posted.
Re: Piaggio X 10
yes , scoot needs to be run in, i would say with a stock setup, the advantage would be no carbon deposit build up, start with a clean engine and keep it that way..frankiej1949 wrote:I put them in as soon as I got the 500 but I took them out after a week and went back to the NGK's to see the difference. Also thought the cvt and clutch needed to settle in too. I will put them back after its first service tomorrow. Will keep you posted.
- SoloSzabi
- Current Ride: Tmax Mk2
Re: Piaggio X 10
That looks awesomefrankiej1949 wrote:I put them in as soon as I got the 500 but I took them out after a week and went back to the NGK's to see the difference. Also thought the cvt and clutch needed to settle in too. I will put them back after its first service tomorrow. Will keep you posted.
Btw, do you recommend to change the spark plug on the 350?
Are we there yet?
Re: Piaggio X 10
not sure which one you use, do you know whats in there nowSoloSzabi wrote:That looks awesomefrankiej1949 wrote:I put them in as soon as I got the 500 but I took them out after a week and went back to the NGK's to see the difference. Also thought the cvt and clutch needed to settle in too. I will put them back after its first service tomorrow. Will keep you posted.
- SoloSzabi
- frankiej1949
Re: Piaggio X 10
I did change the plug on the 350 and it gave a noticeable change. Instant ignition, no deposits on the plug and improved the torque.
