But thats what I've been saying, that the Clutch and variator DIS-ENGAGES, so you have no drive, if you put a geared bike into neutral what happends, OOOH you have NO drive!! If you re-read what I said you'll see I said 'It was LIKE putting a geared bike into neutral' No where does it say you select neutral. Any way this like all topics on here has strayed a bit lol.MrGrumpy wrote:Errm No... A standard CVT transmission doesn't have a neutral at all. When you stop, the clutch (normally centrifugal) disengages to stop you stalling, but re-engages automatically when you twist the throttle.Earl wrote:
Mr Grumpy you say the fact it goes into neutral everytime you stop would put you off, well your Tmax does it aswell,
cheap mana
				Earl
- Current Ride: Mana 850
Re: cheap mana
Re: cheap mana
Most clutches drop out just above walking pace so dont get the neutral when cornering thing unless its in a carpark
Re: cheap mana
But what you are saying is entirely wrong.Earl wrote:But thats what I've been saying, that the Clutch and variator DIS-ENGAGES, so you have no drive
When you close the throttle on a CVT equipped with a centrifugal clutch you get engine braking right up until such time as the speed drops to near walking pace at which point the centrifugal forces have dropped enough to allow the clutch to disengage.
In the case of Honda's (unbelievably complex) Dual Clutch Transmission, the clutches are moved by hydraulic circuits which are operated by solenoids and the gears are shifted by an electric motor.
The DCT clutch and gear movement are controlled by the ECU, the drive remains constant so long as the ECU senses that the wheels are turning.
				Earl
Re: cheap mana
Oh is that not what I said? I didn't mention at what speed did I? So I'm not entirely wrong am I?gn2 wrote:But what you are saying is entirely wrong.Earl wrote:But thats what I've been saying, that the Clutch and variator DIS-ENGAGES, so you have no drive
And any way who gives a flying f**k, I have a Mana and I like it!
Re: cheap mana
Well actually...Earl wrote:Oh is that not what I said? I didn't mention at what speed did I? So I'm not entirely wrong am I?
http://www.maxi-muppets.co.uk/forum/vie ... 64#p161864Earl wrote:Plus I was always told to never shut the throttle off completely because you then dis-engage the variator and are basically free wheeling round the bend hence the slight lag when you come to exit, which is like knocking a geared bike into neutral in the bend then back into first as you come out of it
Re: cheap mana
What a thread
Only posted to show a cheap mana.
				maxine500
- Current Ride: T-Max Street Triple R
Re: cheap mana
 where's my popcorn?
 where's my popcorn?- Ferrit
- Current Ride: MP3 400ie
Re: cheap mana
But this is Muppets.....we can turn a simple bike meeting into 30 pagesStevenM wrote:What a thread
				Earl
Re: cheap mana
And that shows where I said at a certain speed exactly? I'm suprised this post got to 6 or 7 pages without you jumping in PMSL!gn2 wrote:Well actually...Earl wrote:Oh is that not what I said? I didn't mention at what speed did I? So I'm not entirely wrong am I?http://www.maxi-muppets.co.uk/forum/vie ... 64#p161864Earl wrote:Plus I was always told to never shut the throttle off completely because you then dis-engage the variator and are basically free wheeling round the bend hence the slight lag when you come to exit, which is like knocking a geared bike into neutral in the bend then back into first as you come out of it
Re: cheap mana
OK...to delve into pedantry...yes, a CVT transmission clutch disengages (Not the CVT itself), but it of course reengages immediately the throttle opens. So - being pedantic - on a CVT you can never have no drive. It is a wonderfully arcane point to argue whether a CVT with clutch disengaged is or isn't in 'neutral', though the effect is the same. I'd also say that there is a difference on a manual bike/car between being in Neutral (ie no gear selected) and being at rest with the clutch pulled (but in gear). The CVT is closer to the latter situation than the former. At risk of exploring yet further heights of pedantry, I seem to recall (sorry, can't be bothered to re-check precise words) your post said that the DCT went into Neutral 'just like my TMax does'. I would argue that the TMax doesn't....Earl wrote:
